Help! Updating mobo for kaveri cpu
Alright, so if the CPU you had was an FM2 Socket CPU, and you're upgrading to a Socket FM2+ cpu, youll need to put the FM2 socket CPU back in, in order to Update/Flash your BIOS.
If you aleready had a FM2+ Socket CPU in the motherboard and it was working fine, then ignore the above.
1. Visit this website: "http://www.gigabyte.com/products/product-page.aspx?pid=4875#bios" without quotations, and I would recommend downloading The "F4" Update for your BIOS,
2. Itll download as an exe for 7zip, so just double click the .exe and have it extract to your preferred location.
3. Make sure to have a USB flash drive that is formatted, then Place the files you extracted on the USB Flash Drive.
4. Shut Down your PC, and Proceed into your BIOS, usually it's the "Delete" Key.
5. I think there should be something called "M-Flash" (I think that's for MSI motherboards not sure) It should say something along the name of having "Flash" In it.
6. If step 4-5 didn't work, then restart your PC again, and instead of hitting "Delete" Hit "F12" on bootup, itll bring up the Boot Drive list. When it pops up, Choose your USB Flash Drive and that should be it!
