Okay, so long story short, my phone broke, so i bought a second hand one and turns out it was pretty... not good. it was an S3 with real bad battery problems which i couldnt be bothered to replace because it's so slow and now it doesn't get service anywhere.
I'm coming from an HTC One M7 originally which i loved and i was thinking about just buying another, but i thought i'd see if anyone on here reccomended a different phone for around the same price :) $250 nzd ish which is $160 usd :)
https://linustechtips.com/topic/459356-phone-help/
Zenfone 2
4gb varient 16gb of internal space 12 counting all the bloatware
1.7ghz intel atom quadcore x86 so you can basically run windows 3000mA battery 5.5 inch screen 1920x1080p
all for 230 USD
200$ version has all that except 2gb of ram
Moto g 2/3nd gen
150USD
1gb of ram
5inch 720p screen
2300 mAh battery
8gb of storage
5 without bloatware
https://linustechtips.com/topic/459356-phone-help/#findComment-6164399
Zenfone 2
all for 230 USD
Moto g 2/3nd gen
150USD
1gb of ram
5inch 720p screen
2300 mAh battery
8gb of storage
5 without bloatware
Zenfone looks cool! thanks ill look into that on ea bit more, the Moto G however, not sure i can use a phone daily with 1gb of ram, i find the waiting a bit tedious :P
thanks again! :)
https://linustechtips.com/topic/459356-phone-help/#findComment-6164447
