Hello,
So i am installing a second gpu in my build, and i was wondering if i could use a second power supply for to power the extra card instead of replacing my original power supply by using the 6/8 pin pcie connectors.
AMD Ryzen R7 1700 (3.8ghz) w/ NH-D14, EVGA RTX 2080 XC (stock), 4*4GB DDR4 3000MT/s RAM, Gigabyte AB350-Gaming-3 MB, CX750M PSU, 1.5TB SDD + 7TB HDD, Phanteks enthoo pro case
https://linustechtips.com/topic/458922-second-power-supply-for-gpu/
I have a cx 750m and pan on using a cx 500 for my second r9 290x
You can, but you will need a connector to turn on both PSUs when you press the power button.
Replacing the PSU is most likely the better option, what is your current one?
You can get a loom to do this function, like this one
I was thinking of using the 8 pin connectors on the psu to power the gpu.
I heard the cx series have a bad reputation, is the gs 800 a good psu, i can get it for cheap.
The CX are not meant for GPUs at all - using one with 1 card, let alone 2 is a dangerous endeavour as it can easily overload it's heat tolerance and result in a failed PSU and potentially system damage.
I'd strongly suggest getting a decet 750W PSU such as the EVGA G2/GS, SeaSonic M12II/S12G/G-series, Super Flower Leadex/Golden Greeen or Antec High Current Gamer/Pro/Platinum
750W is all you need for SLI or CF for the most part.
Due to the design of certain power supplies, it is not recommended that you run a GPU on a secondary PSU. Group-regulated power supplies like the Corsair VS/CX, Seasonic S/M12II-B 380-600w and it's rebrands (Antec HCG-400-600 / M, XFX Core Edition / ProSeries / TS 450 / 550w, PCP&C Silencer MKIII 400-600w, etc), Cooler Master B, FSP Aurum Gold / CM, etc. are not design to handle such a load.
You are putting zero load on the 3.3/5v and a high, dynamic load on the 12v, in which you are putting the PSU in a crossload scenario where you will see poor voltage regulation.
You want to get an independent regulated power supply via dual mag-amp or DC-DC. Something like the Cooler Master GM, Seasonic G / S12G, Corsair CS and above, Seasonic S/M12II B 650w+, Fractal Design Integra M, Antec VPF / Earthwatt Green, etc.
TBH, since you will likely going to be buying a new power supply to do this, I would just go ahead and buy a new single PSU that can power you entire system. I'm sure you are able to find an affordable, quality unit in your price range. This way, you don't have a box with dangling wires on your desk (or where ever you are putting it) or the need to buy a case with dual PSU support (which cost money).
