Memory speed question
Go to solution Solved by squirrl,
you should be reading 933mhz there
I have 1866 MHz rated corsair vengeance pro memory running on a new z87 Msi gd65 gaming mobo. A kit of 2x 8gb paired sticks.
I'm not quite sure of all the settings and how it's supposed to behave. I have it set at base mhz set to auto and clock to ddr3-1866 MHz with XMP on.
CPU-z reports 800 MHz at idle and 3900 MHz at load.
Is this right?
GamingPC: Intel 4770k CPU, 2xMSI 780 GTX Twin Frozr, 16 GB Corsair Vengeance Pro, Swiftech H220 CPU Cooler.
Cookie Cutter Build log
https://linustechtips.com/topic/45870-memory-speed-question/
Is this right?
I think that's the CPU frequency, not the RAM...
There's a time and place for everything! But not now. - Professor Oak
i7 2600K 4.3GHz  -  GTX 1060 3GB  - ASUS P8Z68-V - 16GB DDR3-1600 CL9 - EIZO 1080p 120Hz VA
Intel Skulltrail: 2x Core 2 Quad QX9775 - Intel D5400XS - 16GB FB DDR2-800 CL5 Quad Channel
EVGA SR-2 Classified - 2x Xeon X5675 4.2GHz - 24GB DDR3-1830 C10 Triple Channel
Intel Skulltrail #2: 2x Xeon E5472  - Intel D5400XS - 16GB FB DDR2-667 CL5 Quad Channel
https://linustechtips.com/topic/45870-memory-speed-question/#findComment-603807
The XMP should be fine, just check that the voltage is 1.5V and the timings are 9-10-9-27.
https://linustechtips.com/topic/45870-memory-speed-question/#findComment-603813
I think you're reading your CPU speed there. If it's set to 1866 in the BIOS then it should run at that speed as for the timings i would check the manufacturers website for them and check them in your bios
Simple Stryker (Now Finished  ;) )
The Terrible HP
https://linustechtips.com/topic/45870-memory-speed-question/#findComment-603816
Is this right?
Can you confirm that you are looking under the "Memory" tab? Because 800MHz is the proper clock for 1600MHz RAM, but 3900MHz RAM doesn't exist. I believe you're looking under the CPU tab.
15" MBP TB
AMD 5800X | Gigabyte Aorus Master | EVGA 2060 KO Ultra | Define 7 || Blade Server: Intel 3570k | GD65 | Corsair C70 | 13TB
https://linustechtips.com/topic/45870-memory-speed-question/#findComment-603818
Aragorn (WS): 250D | 6800k | 840 Pro 512GB | Intel 530 480GB  | Asus X99-M WS | 64GB DDR4 | Corsair HX720i | GTX 1070 | Corsair H115i | Philips BDM4350UC 43" 3840x2160 IPS
Gimli (server):  Node 304 | G4560 | ADATA XPG SX8000 128GB | 2x 5TB WD Red | ASROCK H270M-ITX/AC  | 8GB DDR4 | Seasonic 400FL
 Omega (server):                 Fractal Arc Mini R2 | i3 4130 | 500GB Maxtor | 2TB WD Red : Raid 1 | 3TB Seagate Barracuda | 16GB RAM | Seasonic G-450w
Alpha (WS): 900D | 4770k | GTX 780  | 840 Pro 512GB  | GA-Z87X-OC | Corsair RM 850 | 24GB 2400mhz | Samsung S27B970D 2560x1440
https://linustechtips.com/topic/45870-memory-speed-question/#findComment-603881
I was expecting to read 1866mhz somewhere in CPU-z is all.. But it doesn't
Because of the way RAM, you double it to get the actually frequency. (so you double the NB/DRAM frequency that it reports).
15" MBP TB
https://linustechtips.com/topic/45870-memory-speed-question/#findComment-603945
