Metro 2033
Go to solution Solved by Volbet,
Does the GPU underperforme in other games? Do you use the latest driver?
Also if you are running Metro 2033 with AA and DoF it just kills FPS
Hello there,
I've just got Metro 2033, but it's totally unplayable for me.
Actually, for 2 reasons:
1. Sad fps. Even though I have a gtx 770, I get 30-40-ish frames that sometimes drop; I should get a lot more, why did I pay for this card otherwise ._.
2. Crashing. It constantly crashes after about 1 minute of playing. Sometimes it just doesn't move anymore, sometimes it shows the screen split in 4 squares that all have another color...
Can anyone help? Would it be possible to return this GPU since it's so sadly underperforming etc.? :(
Thanks.
i5 4670k - MSI GTX 770 gaming - Fractal design define R4 (windowed) - MSI Z87-G45 gaming - be quiet! Dark Rock Pro 2 - Corsair vengeance 8 gb (lp) - WB black 1tb - 256GB SSD - Corsair TX 750M - Ducky Shine 3
https://linustechtips.com/topic/45849-metro-2033/
Nova doctrina terribilis sit perdere
Audio format guides: Vinyl records | Cassette tapes
https://linustechtips.com/topic/45849-metro-2033/#findComment-603489
Hello there,
Thanks.
metro 2033 and last light are optimized badly, they make my 660 Ti drop to 7 FPS at random even at lowest settings, where the usual fps hangs around 40-60 FPS on high until the fps drop happens then I have to finish the map before it gets back to normal, sometimes I'm able to play for hours without this happening though.
CPU: R5 1600 @ 4.2 GHz; GPU: Asus STRIX & Gigabyte g1 GTX 1070 SLI; RAM: 16 GB Corsair vengeance 3200 MHz ; Mobo: Asrock Taichi x470; SSD: 512 gb Samsung 950 Pro Storage: 5x Seagate 2TB drives; 1x 2TB WD PurplePSU: 700 Watt Huntkey; Peripherals: Acer S277HK 4K Monitor; Logitech G502 gaming mouse; Corsair K95 Mechanical keyboard; 5.1 Logitech x530 sound system
 01000010 01101001 01101110 01100001 01110010 01111001 00100000 01100100 01101111 01100101 01110011 01101110 00100111 01110100 00100000 01101101 01100001 01101011 01100101 00100000 01111001 01101111 01110101 00100000 01110000 01110010 01101111 00101110
https://linustechtips.com/topic/45849-metro-2033/#findComment-603501
I do not have exact numbers but in pretty much every game it 'feels' like it's not performing as it should.
Latest drivers: yes.
It still seems to crash, does anyone have any experience with this too?
https://linustechtips.com/topic/45849-metro-2033/#findComment-603528
Try and run 3DMark and see if the result is as high as it should be.
I had a problem with Metro: Last Light that was caused Physx, I don't have that problem with 2033 though
https://linustechtips.com/topic/45849-metro-2033/#findComment-603541
Should be a little higher, comparing to other gtx770 + 4670k scores.
https://linustechtips.com/topic/45849-metro-2033/#findComment-603649
Hmm, have you monitored the card with MSi Afterburner to if it boosts as it should and what temps it gets. Also check if your CPU throttles
https://linustechtips.com/topic/45849-metro-2033/#findComment-603683
It does bosst but that doesn't seem to give any performance in-game somehow and I can't test it in metro because it's totally unplayable thanks to the crashing.
My CPU shouldn't throttle since it's kept relatively cool, although I find it too warm for my dark rock pro 2 :p
https://linustechtips.com/topic/45849-metro-2033/#findComment-603828
I've played 2033 on 5 different PC's and I've never had it crash even after hours of playing.
-The Bellerophon- Obsidian 550D-i5-3570k@4.5Ghz -Asus Sabertooth Z77-16GB Corsair Dominator Platinum 1866Mhz-x2 EVGA GTX 760 Dual FTW 4GB-Creative Sound Blaster XF-i Titanium-OCZ Vertex Plus 120GB-Seagate Barracuda 2TB- https://linustechtips.com/main/topic/60154-the-not-really-a-build-log-build-log/ Twofold http://linustechtips.com/main/topic/121043-twofold-a-dual-itx-system/ How great is EVGA? http://linustechtips.com/main/topic/110662-evga-how-great-are-they/#entry1478299
https://linustechtips.com/topic/45849-metro-2033/#findComment-603832
My CPU shouldn't throttle since it's kept relatively cool, although I find it too warm for my dark rock pro 2 :P
Is it the driver you're on the latest WHQL driver or the latest beta driver?
https://linustechtips.com/topic/45849-metro-2033/#findComment-603865
It says it's the 320.49 driver, that's all I have knowledge about.
https://linustechtips.com/topic/45849-metro-2033/#findComment-603888
Try and download the latest beta driver. The older ones aren't suited for the 7xx series cards
http://www.geforce.com/drivers
https://linustechtips.com/topic/45849-metro-2033/#findComment-603901
Using the GeForce experience, I installed the drivers I had again, and for some reason Metro has not crashed yet and runs at minimal 45 fps, in some places it even runs at 90-110 :)
If it decides to crash again, I'll certainly try those beta drivers, thanks for all the help!
https://linustechtips.com/topic/45849-metro-2033/#findComment-604067
Every pc gamer deserve better than dodgy console ports and rushed incomplete games, speaking of which, Visit  PCgamingwiki for un official patches, bug fixes, FOV fixes and more! For more info visit http://pcgamingwiki.com/wiki/Home, search by game.
I think I should add that site to my signature, I've shamelessly plugged it so many times, at this rate  it would be more efficient to just post a copy/paste message like
--check my signature--
https://linustechtips.com/topic/45849-metro-2033/#findComment-604257
