So my laptop refuses to go above 1ghz in any power plan if its on battery and the battery level is below 40%. i tried looking into the bios to see if i could disable anything that could be preventing the cpu to run normally but I found nothing. Any suggestions? I have a lenovo y40
https://linustechtips.com/topic/458083-laptop-cpu-management-problems/
we need a bit more info then that
If you need remote help fixing something on your computer
I can help over Teamviewer if you wish
just msg me on my profile
My laptop runs very cool, right now it's running at 43c. My powerplan for balanced (which is what i use) is min 40% and max 100% so obviously my computer is doing something wrong but i can't pinpoint it.  Any more info that you need?
make and model of the laptop
and some details of its specs (use cpu-z or pc wizard if you don't know)
set it to min 100 and max 100 and se what happens
The Ninja (current gaming pc)  Case- h440 red/black cpu- i5-4690k@ 4.3ghz cooler- coolermaster hyper 212 evo moboGigabyte z97x-sli ram- adata xpg v.1 2x4gb 1600mhz gpu- asus strix gtx 970 hdd- wd blue 1tb ssd- kingston hyperx savage 240gb psu- evga 600b peripherals: mouse- razer death adder 2013 keyboard- corsair k70 with chery mx-reds headset- HyperX Cloud 2
my laptop- toshiba satelite p850, cpu- i7-3630qm ram- 8gb 1600mhz hdd- 1tb 5400rpm gpu- Nvidia gt630m 2gb
did you know we have a gun thread ? well we do
and a car thread !
lenovo y40.
broadwell i5 5200u
R9 m275 2gb
8gb of ram
1tb hdd
ahh its a broadwell
I have a feeling you are getting confused between power saving mode and full blow speed
what I would do is stress test the cpu for 10 mins and monitor the cpu and its clock speed for that 10 mins
I would guess it that it would go up to its full speed
ahh its a broadwell
it does, the cpu is completely fine before the battery gets drained to 40%. it has no problem clocking to 2.4- 2.6 ghz but when the battery goes under 40% it refuses to go above 800mhz thats the problem that I can't figure out.
 I also used intels diagnostic tool and the cpu checked out fine.
take the battery out totally
and test it...
