Windows installation wont work! Really need help!
Go to solution Solved by mouse18,
Installing via USB. The windows software will not detect my hard drive. I dont know why. It is however being detected in the bios.
EDIT: Well i managed to partition the drive for 1MB less than it should have on it and it is now being fully detected by windows.
A required CD/DVD drive device driver is missing. This comes up every time i am using a ASUS m5a98 r2.0 board. I have downlaoded the raid drivers. The only drivers that show up in the box are the x86 AHCI Drivers which do not find my device. If i go into the bios my HDD is clearly detected there. Does anyone have any solutions? I cant find anything anywhere.
So how are you installing windows? Through a Cd or usb? And is it installed but not fully functional or is it not detecting the CD windows is on?
Motherboard- P8Z77V-LK CPU- i5 3570K @4.3 RAM- 8gb of Corsair Vengence GPU- MSI 660ti Power Edition PSU- CX750M SSD- Samsung 840t HDD- 1tb of WD Black Case- Modded Bitfenix Shinobi Cooling- H80i and Bitfenix Spectre fans and Bitfenix LED fans
