Can an any brands of gtx 980ti or titan x/ r9 390 or r9 fury be fitted into fractal core 1100 matx?
Probably. The case fits graphics cards up to 350mm in length or 170mm with 3.5" hdd's installed.
Whether a graphics card will fit in a case depends on the card's dimensions and the case's clearance for it. Both can usually be found on the respective component's web page.
You need to quote a post or tag a member or else they won't get a notification you replied to them.
