Price & Location
i live in australia and have $1500 to spend
Aim:
gameing mostly but would like to do some rendering and video editing down the road.
Monitors:
a monitor will be needed 24" prefered
Periferals:
not really needed but would be nice to get a better mouse and keyboard
Upgradeing:
from my 4 year old laptop that was strugling with modern games
cpu: i5 4670k
mobo: ASUS z87 gryphon
case: corsair 350d
gpu: evga 760 superclocked 2gb
psu: thermaltake 650w 80+ bronze
ram: 8gb corsair vengence pro 1600ghz
hhd: 1tb wd black
monitor: Benq GL2460HM 24"
i would love to hear the your opinions.
https://linustechtips.com/topic/45748-1500-first-build/
I would get a different power supply like one from xfx, seasonic, nzxt, fractal design, or corsair. For the monitor I would recommend something like a asus pb238q or dell u2312hm, they may be 23in, but they are nicer screens. Why cheapout on the thing you will be staring at while using the computer.
https://linustechtips.com/topic/45748-1500-first-build/#findComment-602287
Hey, bud. Was there anything you didn't want to change with your suggested build? Especially with appearance. Also see that you chose a K edition processor, so you should invest in a aftermarket CPU cooler if you want to overclock.
"And yet my mind is screaming, provoked in an icy sweat. It’s pleading and begging for a release, scraping the walls of a padded cell, pounding hopelessly at the floors that won’t even deliver the gift of pain."  - Why I Don't Dream Anymore
https://linustechtips.com/topic/45748-1500-first-build/#findComment-602316
The BenQ you chose I believe is nothing special. You should get the XL2420t if you want 120hz or a good IPS panel like the PB238Q. Also I recommend a 7950 over a 760.
i5 4670k | Sapphire 7950 | Kingston 120GB SSD | Seagate 1TB | G.Skill Ripjaw X Series 8GB
PB238Q | Steelseries Sensei | Ducky DK9087 | Qck Heavy
Build Log: http://linustechtips.com/main/topic/44902-from-imac-to-my-own-creation/
https://linustechtips.com/topic/45748-1500-first-build/#findComment-602376
i plan on getting a H100i or 80i as soon as i have the funds as well as a ssd
as for other psu's i have to chose from any of these
 Aerocool VP750 750W True Power
 CFI 700W 80+ Silver Power Supply
Antec VP650P 650W Power Supply
Xigmatek Vector S 750W 80+ Silver
Corsair VS650 ATX Power Supply
and the monitor i really do wish i had the money to buy the XL2420T but since i will most likely be getting another monitor in the future i will keep the Benq GL2460HM 24" for a start.
if you think there are any other components that need to be swapped out for something please let me know
https://linustechtips.com/topic/45748-1500-first-build/#findComment-602987
why you add me as a friend gamer?
        # -_-     [Planned RIg AKA Project ARES    -_-#
| AMD FX-8350 4.0GHz 8-Core | Be Quiet DARK ROCK 2 57.9 CFM Fluid Dynamic Bearing | Asus Crosshair V Formula-Z  |G.Skill Ripjaws X 8GB Western Digital Caviar Black 1TB 3.5" 7200RPM |Samsung 840 Series 250GB 2.5" SSD | Sapphire Radeon HD 7970 3GB  |Fractal Design Define R4 w/Window (Black Pearl) ATX Mid Tower|Gelid Solutions Silent 14 PWM 74.5 CFM 140mm x3 |Corsair RM Series 750 Watt ATX/EPS 80PLUS Gold-Certified Power Supply|
|Rosewill RNX-N250PCe | Windows 8  | Acer H236HLbid 23.0" |Corsair Vengeance K70
Corsair Vengeance M65 Wired Laser | STEELSERIES QCK Black|Sennheiser HD 558Asus DRW-24B1ST/BLK/B/AS DVD/CD Writer
https://linustechtips.com/topic/45748-1500-first-build/#findComment-603257
How heavy is the editing/rendering that you're planning to do?
https://linustechtips.com/topic/45748-1500-first-build/#findComment-608143
