Costs the same as what air cooler ? Some air coolers are better than liquid coolers.
keep telling yourself that.
https://linustechtips.com/topic/457064-water-or-air-cooling/#findComment-6133939
Take a good air cooler (Noctua) does the same job as a water cooling and it will last for ever
water cooling after 2 years...... start the problems
CPU:i7 9700k 5047.5Mhz All Cores Mobo: MSI MPG Z390 Gaming Edge AC, RAM:Corsair Vengeance LPX 16GB 3200MHz DDR4 OC 3467Mhz GPU:MSI RTX 2070 ARMOR 8GB OC Storage:Samsung SSD 970 EVO NVMe M.2 250GB, 2x SSD ADATA PRO SP900 256GB, HDD WD CB 2TB, HDD GREEN 2TB PSU: Seasonic focus plus 750w Gold Display(s): 1st: LG 27UK650-W, 4K, IPS, HDR10, 10bit(8bit + A-FRC). 2nd: Samsung 24" LED Monitor (SE390), Cooling:Fazn CPU Cooler Aero 120T Push/pull Corsair ML PRO Fans Keyboard: Corsair K95 Platinum RGB mx Rapidfire Mouse:Razer Naga Chroma  Headset: Razer Kraken 7.1 Chroma Sound: Logitech X-540 5.1 Surround Sound Speaker Case: Modded Case Inverted, 5 intake 120mm, one exhaust 120mm.
https://linustechtips.com/topic/457064-water-or-air-cooling/#findComment-6133964
  • 2 weeks later...
Watch Linus' video on the Noctua NH-D15. It even beats the H100 and gets close to the H110. They've even said before, just cause it's water doesn't mean it's better.
Though, custom water cooling is always the best option (even though it is potentially dangerous for your components and it's very expensive.)
GAMING PC "Ol' Bessie":
Ryzen 7 7800X3D | Radeon RX 9070 XT | Gigabyte B650M AORUS Elite AX | G.Skill Flare X5 6000MT/s CL36 16GBx2 | 5TB of SSD POWER | EVGA SuperNOVA 850W GT | Noctua NH-U14S | Fractal Design Pop! Mini AirCachyOS
Kind Of A Home Lab "Bay":
Ryzen 9 5900XT | Intel ARC A310 | ASUS PRIME B550-PLUS | T-FORCE 3200MT/s 16GBx2 + Corsair 3200MT/s 32GBx2 = 96GB!!! WOW!! | 2TB boot SSD + 8TBx6 HDD RaidZ2 | EVGA SuperNOVA 650W G2 | Phanteks Enthoo Pro M | Ubuntu 24.04 LTS
The Laptop:
Framework Laptop 13 | Intel i5-1340p | G.Skill Ripjaws 3200MT/s 16GBx2 | Solidigm P44 Pro 2TB | CachyOS
https://linustechtips.com/topic/457064-water-or-air-cooling/#findComment-6203375
What are you cooling? What kind of dollars are you using?
https://linustechtips.com/topic/457064-water-or-air-cooling/#findComment-6203467
of course in some situations air cooling is the better option but the best aio is better than the best air cooler
https://linustechtips.com/topic/457064-water-or-air-cooling/#findComment-6204636
