Try 4.4 at 1.25. Volts. That works for the vast majority of g3258s even for shitty overclocking ones. But be careful what cooler you've got
I am a member of the PCMasterRace. I am terribly sad to announce that I own a PeasantStation 3 Super Slim. it's in a drawer away from my glorious PC.
F@H stats:http://fah-web.stanford.edu/cgi-bin/main.py?qtype=userpage&username=AngelKoura
https://linustechtips.com/topic/457049-pentium-g3258-oc-help/#findComment-6133724
I'm running 4Ghz with a H100i GTX At 50 Degree Celsius when full load at stock voltage
You have a good overclocker on your hands. Push that little bitch a bit more.
https://linustechtips.com/topic/457049-pentium-g3258-oc-help/#findComment-6134024
True but if I push it more to 4.35Ghz , than windows wouldn't boot and it will just crash. What's wrong?
you reached an instability. apply more voltage to it and then test it.
https://linustechtips.com/topic/457049-pentium-g3258-oc-help/#findComment-6134361
Not enough volts, add MORE.
LTT's Fastest single core CineBench 11.5/15 score on air with i7-4790K on air
Main Rig
CPU: i7-4770K @ 4.3GHz 1.18v, Cooler: Noctua NH-U14S, Motherboard: Asus Sabertooth Mark 2, RAM: 16 GB G.Skill Sniper Series @ 1866MHz, GPU: EVGA 980Ti Classified @ 1507/1977MHz , Storage: 500GB 850 EVO, WD Cavier Black/Blue 1TB+1TB,  Power Supply: Corsair HX 750W, Case: Fractal Design r4 Black Pearl w/ Window, OS: Windows 10 Home 64bit
Plex Server WIP
CPU: i5-3570K, Cooler: Stock, Motherboard: ASrock, Ram: 16GB, GPU: Intel igpu, Storage: 120GB Kingston SSD, 6TB WD Red, Powersupply: Corsair TX 750W, Case: Corsair Carbide Spec-01 OS: Windows 10
Lenovo Legion Laptop
CPU: i7-7700HQ, RAM: 8GB, GPU: 1050Ti 4GB, Storage: 500GB Crucial MX500, OS: Windows 10
https://linustechtips.com/topic/457049-pentium-g3258-oc-help/#findComment-6134491
