I am looking to build a mini itx computer that can handle photo shop. It doesnt need to be a great gaming rig jusat a great photo editing machine. I have a budget of 600ish dollars. What type of parts are most important I belive it would go Ram Cpu ssd gpu. What do you suggest. Thank you for your help
https://linustechtips.com/topic/456949-mini-itx-photoshop-machine/
Are you at all interested in an all in one PC? Because this one isn't too bad for the money, it has a 1080p IPS touch display and a full desktop 7800 APU in it
$649
http://www.newegg.com/Product/Product.aspx?Item=N82E16883282447
Going to suggest a compact APU rig otherwise, only main difference from the all in one above is more RAM and the all in one cooler, unless you're doing some crazy photoshop work you should be good to go, maybe throw in an SSD as well, you could fit a 480GB SSD in if you drop the all in one cooler
http://pcpartpicker.com/p/dtxBBm
PCPartPicker part list: http://pcpartpicker.com/p/dtxBBm
Price breakdown by merchant: http://pcpartpicker.com/p/dtxBBm/by_merchant/
CPU: AMD A10-7870K 3.9GHz Quad-Core Processor  ($139.99 @ Amazon)
CPU Cooler: Cooler Master Seidon 120M 86.2 CFM Liquid CPU Cooler  ($64.99 @ Newegg)
Motherboard: ASRock FM2A88X-ITX+ Mini ITX FM2+ Motherboard  ($94.89 @ OutletPC)
Memory: G.Skill Ripjaws X Series 16GB (2 x 8GB) DDR3-2400 Memory  ($83.99 @ Newegg)
Storage: Western Digital Caviar Blue 1TB 3.5" 7200RPM Internal Hard Drive  ($49.89 @ OutletPC)
Case: Cooler Master Elite 130 Mini ITX Tower Case  ($43.99 @ SuperBiiz)
Power Supply: Rosewill 550W 80+ Bronze Certified Semi-Modular ATX Power Supply  ($59.89 @ OutletPC)
Total: $537.63
Generated by PCPartPicker 2015-09-27 00:20 EDT-0400
CPU: Intel Core i5-4460 3.2GHz Quad-Core Processor  ($165.99 @ SuperBiiz)
Motherboard: MSI H97 PC MATE ATX LGA1150 Motherboard  ($88.99 @ SuperBiiz)
Storage: Sandisk Ultra Plus 256GB 2.5" Solid State Drive  ($79.99 @ NCIX US)
Video Card: Club 3D Radeon R9 270 2GB Video Card  ($149.00 @ Amazon)
Case: NZXT Source 210 Elite (White) ATX Mid Tower Case  ($42.99 @ Directron)
Power Supply: EVGA 500W 80+ Bronze Certified ATX Power Supply  ($47.99 @ SuperBiiz)
Total: $609.94
Generated by PCPartPicker 2015-09-27 00:08 EDT-0400
CPU: A8-5600K GPU: MSI RX 480 GAMING X 4GB MOBO: ASUS A55BM-PLUS
RAM: 2x 4GB Samsung DDR3-1600 1.25V PSU: Corsair CX430 CASE: Enermax Ostrog Windowed STORAGE: PNY CS1111 120GB / Hitachi 1TB 7200RPM OS: Windows 10 Pro & macOS Sierra 10.12.3
4 cores, 8 threads, 4 GB VRAM, and an SSHD for faster boot on a budget.
CPU: Intel Xeon E3-1220 V3 3.1GHz Quad-Core Processor  ($192.99 @ SuperBiiz)
Motherboard: ASRock H81M-ITX Mini ITX LGA1150 Motherboard  ($58.99 @ SuperBiiz)
Memory: Team Dark 8GB (1 x 8GB) DDR3-1600 Memory  ($34.99 @ Newegg)
Video Card: Gigabyte GeForce GTX 750 Ti 4GB Video Card  ($149.99 @ Amazon)
Total: $609.43
Generated by PCPartPicker 2015-09-27 00:13 EDT-0400
Intel Core i7-6700K | Corsair H105 | Asus Z170I PRO GAMING | G.Skill TridentZ Series 16GB | 950 PRO 512GB M.2
Asus GeForce GTX 980 Ti 6GB STRIX OC | BitFenix Prodigy (Black/Red) | XFX PRO Black Edition 850W
My BuildPCPartPicker | CoC
Total: $609.94
I need it to be as tiny as possible so i can take it with my when i travel like in my carry on
$649
Otherwise if you already have a nice display gimme a minute
Im not looking for all in 1 per say but ill keep this in mind
Total: $609.43
This is about what i was thinking would 8gigs of ram be enough tho?
PCPartPicker part list: http://pcpartpicker.com/p/GMfTkL
Price breakdown by merchant: http://pcpartpicker.com/p/GMfTkL/by_merchant/
Motherboard: ASRock H97M-ITX/AC Mini ITX LGA1150 Motherboard ($78.98 @ Newegg)
Storage: A-Data Premier Pro SP600 128GB 2.5" Solid State Drive ($47.99 @ Amazon)
Video Card: PowerColor Radeon R9 380 4GB PCS+ Video Card ($173.98 @ Newegg)
Case: Cooler Master Elite 120 Advanced (Black) Mini ITX Tower Case ($29.99 @ Newegg)
Power Supply: EVGA SuperNOVA NEX 750W 80+ Bronze Certified Semi-Modular ATX Power Supply ($49.99 @ Newegg)
Total: $616.90
Generated by PCPartPicker 2015-09-27 00:21 EDT-0400
If you can afford the extra $40 you can get another 1x8 kit.
You'll want to go with one of these In win cases then
http://pcpartpicker.com/p/nsHmMp
But that's if you're feeling crazy, you can change the TDP of the 7800 in the BIOs to 45W and it won't impact performance much
You could also instead go with like an i5, but if you want to do some gaming without a GPU, then the APU would be the way to go
There's also this case option from them with a 200W PSU over a 120W for a bit more headroom, but it is a bit bigger, still really small though for a desktop PC
https://pcpartpicker.com/part/inwin-case-bp655fh200b
Total: $616.90
I really like this build but i thiunk i will need more storage space
Here.
Skylake because good igpu
That case because it's small enough for a carry on
16gb ram because Adobe stuff uses ram afaik
Biggest SSD within budget because you don't want your hard drive being banged around
CPU: Intel Core i5-6500 3.2GHz Quad-Core Processor ($209.99 @ B&H)
Motherboard: ASRock H170M-ITX/DL Mini ITX LGA1151 Motherboard ($92.98 @ Newegg)
Memory: Crucial 16GB (2 x 8GB) DDR4-2133 Memory ($88.99 @ Adorama)
Storage: Crucial BX100 500GB 2.5" Solid State Drive ($156.71 @ Amazon)
Case: Inwin BP655.200BL Mini ITX Desktop Case w/200W Power Supply ($52.98 @ Newegg)
Total: $601.65
Generated by PCPartPicker 2015-09-27 00:34 EDT-0400
G3258 @ 4.5 | 8GB Team Vulcan RAM | 128GB Kingston V300 SSD (I didn't know what I was doing when I bought it) | MSI H81I Motherboard | Corsair H55 with Noctua NF-P12 | EVGA SSC GTX 960 4GB | OCZ 550W Fully Modular PSU with Noctua NF-A14 | Cooler Master Elite 130 (Soon to be something cool)
Here.
Total: $601.65
So you say go with the skylake and use internal gpu what  gpu would you suggest to go with it if i push the budget
Depends on what games you want to play. If none, you don't need any GPU.
