so when playing MGS maxed things are going aok then BAM for what seems like no reason massive fps drop...like sub 24 fps for no reason anyone have any idea whats going on with this?
System Specs
CPU: Ryzen 5 5600x | Mobo: Gigabyte B550i Aorus Pro AX | RAM: Hyper X Fury 3600 64gb | GPU: Nvidia FE 4090 | Storage: WD Blk SN750 NVMe - 1tb, Samsung 860 Evo - 1tb, WD Blk - 6tb/5tb, WD Red - 10tb | PSU:Corsair ax860 | Cooling: AMD Wraith Stealth  Displays: 55" Samsung 4k Q80R, 24" BenQ XL2420TE/XL2411Z & Asus VG248QE | Kb: K70 RGB Blue | Mouse: Logitech G903 | Case: Fractal Torrent RGB | Extra: HTC Vive, Fanatec CSR/Shifters/CSR Elite Pedals w/ Rennsport stand, Thustmaster Warthog HOTAS, Track IR5,, ARCTIC Z3 Pro Triple Monitor Arm | OS: Win 10 Pro 64 bit
https://linustechtips.com/topic/456041-mgs5-massive-fps-drops/
did you see a CPU speed drop by a huge chunk?
Budget? Uses? Currency? Location? Operating System? Peripherals? Monitor? Use PCPartPicker wherever possible.
Quote whom you're replying to, and set option to follow your topics. Or Else we can't see your reply.
https://linustechtips.com/topic/456041-mgs5-massive-fps-drops/#findComment-6119852
wasnt monitoring that will screw around a bit to see but I doubt its a heat issues if theats were you are going which I expect mind tou IU dunno how to monitor that in real time, MSI AB doesnt have a clock speed setting for cpu
System Specs
https://linustechtips.com/topic/456041-mgs5-massive-fps-drops/#findComment-6119858
Check which background process is using your GPU. Use ProcessHacker 2. http://sourceforge.net/projects/processhacker/
https://linustechtips.com/topic/456041-mgs5-massive-fps-drops/#findComment-6119905
Same thing happened to me with MGSV. Not sure of the cause, could be a game bug. Restarting my PC fixed the problem for me.
its unfortunately an on going issue with me
System Specs
https://linustechtips.com/topic/456041-mgs5-massive-fps-drops/#findComment-6123667
and yet my brother's fx-4100/hd 7850 rig sees none of this
check temps/cpu usage
cpu useage you can see in the pic
temps I will check tomorrow
System Specs
https://linustechtips.com/topic/456041-mgs5-massive-fps-drops/#findComment-6123681
