you have a positive set up by the looks of it, keeps dust out of your case.
                     ¸„»°'´¸„»°'´ Vorticalbox `'°«„¸`'°«„¸
`'°«„¸¸„»°'´¸„»°'´`'°«„¸Scientia Potentia est  ¸„»°'´`'°«„¸`'°«„¸¸„»°'´
https://linustechtips.com/topic/455175-how-is-my-airflow/#findComment-6107126
i see to many stray red things blowing and rattling in your case. you should probably take that out.
We can't Benchmark like we used to, but we have our ways. One trick is to shove more GPUs in your computer. Like the time I needed to NV-Link, because I needed a higher HeavenBench score, so I did an SLI, which is what they called NV-Link back in the day. So, I decided to put two GPUs in my computer, which was the style at the time. Now, to add another GPU to your computer, costs a new PSU. Now in those days PSUs said OCZ on them, "Gimme 750W OCZs for an SLI" you'd say. Now where were we? Oh yeah, the important thing was that I had two GPUs in my rig, which was the style at the time! They didn't have RGB PSUs at the time, because of the war. The only thing you could get was those big green ones.
https://linustechtips.com/topic/455175-how-is-my-airflow/#findComment-6107241
Is there top exhaust next to rear? You don't need one of those. In fact, you could move AIO more towards rear and make sure you get more fresh air for GPU. You only need 1 exhaust fan for every 2 intakes so you could remove one of exhausts.
^^^^ That's my post ^^^^
vvvv Who's there? vvvv
https://linustechtips.com/topic/455175-how-is-my-airflow/#findComment-6111895
