Hey'all, lately I've been getting a weird issue with my asus ux305f.
When the cpu is under a medium or high load, nothing happens at all, but when it is under low load or even idle, the screen starts tearing around and glitching seriously often.
One "fix" I found was to open cpu-z and let the stress test run non-stop, but if I ever want to do some work, I need to turn it off and at the slightest load drop or pause I get tearing again 'till I start working quickly and using the cpu heavely, and if I try to work with the stress test on it takes me a really big time to do anything.
Any tips or help for this?
Specs:
intel M 5Y10 @ 0,80GHz
8GB ram
intel hd 5300
screen resolution @ 1280x720 no scaling. (But it came as default with 250% scaling at 3200x1800)
windows 10 pro
https://linustechtips.com/topic/454931-screen-tearing-when-idlelow-load/
Any ideas on how I should fix this? I could put it to default but then some applications get "bugged" and won't scale thus they'll be displayed with really really small fonts.
And regardless of that, the tearing happens anyway...
Install correct driver for your monitor and GPU. This should fix the issue.
CPU: Intel i5-8600K 6C 3.6 GHz | MOBO: ASUS Prime Z370-A ATX Motherboard | RAMCorsair Vengeance RGB 16GB (2 x 8GB) DDR4 3000MHz | GPU: ASUS Dual GeForce GTX 1060 OC edition 6GB | CASE: CoolerMaster MasterBox Lite 5 RGB | PSU: CoolerMaster V750 | SDD: Samsung 840 Pro 250GB | HDD: Seagate Barracuda  3 TB 7200rpm |  Sound Card: (pending)  | Speaker: Logitech Z623
