Can i get a BIG difference between the Asus 970 or MSi 970 ? (for overlock)
AMD - Ryzen 5 2600 3.4GHz 6-Core / Evga 1070ti ftw 2 8 gb/ MSI B450 tomawack / Stock cooler/ G.SKILL 16gb 3000mhz RGB / 860 evo 500 GB /  XL2411 144HZ  / Western digital blue 1 TB 7200 RPM/ Corsair 760T (white) |Window 10 pro
https://linustechtips.com/topic/454627-big-difference/
All depends on the bin. Some ASUS 970s will OC better, some MSI 970s will OC better.
FX-8350 | GA-990FXA-UD3 | G.SKILL 2x8GB 1600MHz | 1TB WD RE4 | CM Hyper 212 EVO | MSI R9 290x Lightning | Corsair AX860i | Silverstone FT05B-W
Pentium G3258 | MSI Z97 PC Mate | G.SKILL 4x4GB 1066MHz | 500GB Samsung 2.5" | Stock cooler | Pending GPU | EVGA 500B | Antec DF-35
GoPro Hero 3 Silver | Netgear R7000 Nighthawk with DD-WRT | HP Officejet Pro 8610 | Canon iP110 | AudioTechnica ATR2500 USB
Downdraft cooler for mITX board (new build) | Desk mount mic stand | Pop filter | Anti-vibration mount for microphone | mITX case | 3rd monitor (matching existing 23.1" | Intel Core i7-4790K (for mITX build)
https://linustechtips.com/topic/454627-big-difference/#findComment-6099339
You wont notice a difference in performance, sure maybe one will clock higher than the other, but the same goes for an MSI card against another MSI card, or an Asus card against an Asus card. Brand doesnt impact the silicon lottery.
https://linustechtips.com/topic/454627-big-difference/#findComment-6099340
Msi normal and asus strix
https://linustechtips.com/topic/454627-big-difference/#findComment-6099352
The biggest difference is ASUS cooler, I mean there maybe like a .0000000005% difference in the frame rates due to MSI's like one or two point higher base clock and boost clock but honestly ASUS is the best for OC
I'm playing my Xbone on 3 LG Curved monitors-No one ever
Please, read CoC it helps, it helped me it should help you-Every competent member
Resident bad pun maker.....please excuse them
https://linustechtips.com/topic/454627-big-difference/#findComment-6099355
Yeah fuck the MSI strix for the win BITCHES!
https://linustechtips.com/topic/454627-big-difference/#findComment-6099358
MSI 970 or 390, pick the cheapest one.
|| Asrock Z68 Extreme 3 Gen 3 || i5 3570 @3.5GHz || Zalman CNPS10X Optima || 8GB RAM HyperX Fury Blue @ 1600MHz || Thermaltake Berlin 630W || Zalman Z11 || Gainward Phantom GTX 970 || 120GB Kingston V300  (Gift) + 1TB  WD Green
Phone: Xiaomi Redmi Note 8
Tablet: iPad Mini 2
https://linustechtips.com/topic/454627-big-difference/#findComment-6099432
for overclocking it dosent matter what 970 you get anymore. at most its a few percent difference in preformance if that at all. (i know people have achieved more[ thats not the point])
get what brand you trust more or prefer. for 970's it straight up dosent matter anymore. anyway the r9 390 preforms better.
CPU: I7 8700k @ 5ghz | Motherboard: Asus Z370-Prime | RAM: White Crucial balistix DDR4 2133mhz | GPU: GTX 1080TI | Storage: ssd HyperX 240gig, 2x2tb seagate Firecuda 1tb, BPX 480 gig nvme, 1tb sandisk ssd  | Cooling: Custom loop | PSU: Evga supernova 850w G2 | Case: Phanteks enthoo evolv atx black White modded | system theme: White/RGB/Weiss
https://linustechtips.com/topic/454627-big-difference/#findComment-6099459
