Is it necessary to do water cooling on memory cards? When is it necessary or suggested to do?
Memory cards? Do you mean graphics cards? Or Memory sticks (RAM) ?
  I mean memory sticks RAM
No.
I mean, you can do it, but it makes next to no difference. and it definitely isn't "necessary" otherwise how the heck do they not overheat without it.
Aftermarket 980Ti >= Fury X >= Reference 980Ti > Fury > 980 > 390X > 390 >= 970 380X > 380 >= 960 > 950 >= 370 > 750Ti = 360
"The Orange Box" || CPU: i5 4690k || RAM: Kingston Hyper X Fury 16GB || Case: Aerocool DS200 (Orange) || Cooler: Cryorig R1 Ultimate || Storage: Kingston SSDNow V300 240GB + WD Black 1TB || PSU: Corsair RM750 || Mobo: ASUS Z97-A || GPU: EVGA GTX 970 FTW+
"Unnamed Form Factor Switch" || CPU: i7 6700K || RAM: Kingston HyperX Fury 16GB || Case: Phanteks Enthoo Evolv Mini ITX (White) || Cooler: Cryorig R1 Ultimate (Green Cover) || Storage: Samsung 850 Evo 1TB || PSU: XFX XTR 550W || Mobo: ASUS Z170I Pro Gaming || GPU: EVGA GTX 970 FTW+
No.
I heard that if the cpu is overclocked, the RAM will heat up. That's why I'm asking.
Well the answer is NO. You don't need to watercool any component AT ALL.
my CPU is heavily OCed and my ram hasn't gotten noticeably hotter.
Welcome to the Forums!
While they get warm they don't get that hot if you want to go all out and watercool everything you can watercool RAM. Also there are stock sticks like the Dominator Platinums that can operate at 3Ghz using just a larger heatspreader.
I heard that if cpu is overclocked, RAM will heat up. Is it true?
welcome to the Linus Tech Tips forums!
unless you are using ridiculous voltages on overclock, the case cooling
method is pretty much all that is needed. the RAM coolers are mainly
for aesthetics and lend minimal performance gains on normal voltages
for overclocking.
Unlike the old days, even ddr3 at 1.65V doesn't need anything more than regular old fashioned heat spreaders.
Water cooling ram is never needed and almost never recommended (because it literally is pointless and only adds an additional failure point.
LINK-> Kurald Galain:  The Night Eternal
Top 5820k, 980ti SLI Build in the World*
CPU: i7-5820k // GPU: SLI MSI 980ti Gaming 6G // Cooling: Full Custom WC //  Mobo: ASUS X99 Sabertooth // Ram: 32GB Crucial Ballistic Sport // Boot SSD: Samsung 850 EVO 500GB
Mass SSD: Crucial M500 960GB  // PSU: EVGA Supernova 850G2 // Case: Fractal Design Define S Windowed // OS: Windows 10 // Mouse: Razer Naga Chroma // Keyboard: Corsair k70 Cherry MX Reds
Headset: Senn RS185 // Monitor: ASUS PG348Q // Devices: Note 10+ - Surface Book 2 15"
LINK-> Ainulindale: Music of the Ainur
Prosumer DYI FreeNAS
CPU: Xeon E3-1231v3  // Cooling: Noctua L9x65 //  Mobo: AsRock E3C224D2I // Ram: 16GB Kingston ECC DDR3-1333
HDDs: 4x HGST Deskstar NAS 3TB  // PSU: EVGA 650GQ // Case: Fractal Design Node 304 // OS: FreeNAS
Na, regular old fashioned heatspreaders is plenty.  Most people only watercool RAM to make their loop have shorter cleaner runs, sometimes it can make tubing everything up easier.
Even benching at 2.1v on my RAM, a 120mm fan pointed at the sticks is enough to keep them about room temperature.  ( PS: Please don't put 2.1v through your RAM unless you know what you're doing lol)
you only water cool ram for 2 reason
#1 is for kicks
#2 you pushing stupid ammounts of volts thur it  for world breaking overclocks
if neither is being done the stock heatsinks are more then fine
also its not cheap to water cool ram at all if you have a 8 dimm board
main rig
 corsair 750d | evga 1000w g2 | Gigabyte x99 soc champ | 5820k 4.0GHz | 1tb wd blue | 250gb samsung 840 evo  | Crucial Ballistix Sport XT 16GB 8x2 DDR4-2400 | MSI GTX 970 x2 | monitor Acer B286HK 28" 4K | razor chroma blackwidow  | razor death adder chroma
CENTOS 7 SERVER (PLEX&docker stuff)
NZXT s220 | evga 500w 80+ | AMD FX 8320e | ASUS M5A78L-M/USB3 | 2x8gb non ecc ddr3 WD red 2TBx2 | seagate 160gb microcenter 8gb flashdrive OS
