Python Project
Solved by martward,
You need to write if express_shipment == 'n' or express-shipment =='no':
There is a difference in python between " and ' (forgot what it was though)
Also I would use: if "y" in express_shipment, it's easier more compact and more robust.
And you don't need an elif if you are not adding an else. Just check whether the input contains a y and use else for if it doesn't.
