I hope I am placing this in the right spot. I am new to Blender, and I can't seem to get this black frame out of my renderings. Could anyone help?
nice keyboard
i got the same
(whats blender?)
OFF TOPIC: I suggest every poll from now on to have "**CK EA" option instead of "Other"
https://linustechtips.com/topic/454117-blender-rendering-issues/#findComment-6091747
Can you give us more specifics on the settings and such?
CPU: Intel i7 - 5820k @ 4.5GHz, Cooler: Corsair H80i, Motherboard: MSI X99S Gaming 7, RAM: Corsair Vengeance LPX 32GB DDR4 2666MHz CL16,
GPU: ASUS GTX 980 Strix, Case: Corsair 900D, PSU: Corsair AX860i 860W, Keyboard: Logitech G19, Mouse: Corsair M95, Storage: Intel 730 Series 480GB SSD, WD 1.5TB Black
Display: BenQ XL2730Z 2560x1440 144Hz
https://linustechtips.com/topic/454117-blender-rendering-issues/#findComment-6092234
Would it be easier if I just sent the template? I don't see any problems with the animation itself (when I preview it), but it doesn't show the background. Again...I am very new to this :P
https://linustechtips.com/topic/454117-blender-rendering-issues/#findComment-6092370
Yeah sure link it ill take a look.
https://linustechtips.com/topic/454117-blender-rendering-issues/#findComment-6093060
Here is the template I'm using:
http://we.tl/VgiVGBgt8l
I get the same result with a single frame render. Im going to be going out to a pub for a couple hours then I will play around with it for a bit. Ill let you know what I found out.
https://linustechtips.com/topic/454117-blender-rendering-issues/#findComment-6101027
Thank you so much! Like I said...I'm new to the software so I don't even know where to begin when it comes to troubleshooting the issue.
https://linustechtips.com/topic/454117-blender-rendering-issues/#findComment-6105875
Im not entirely sure what is wrong with it, I've rendered all 330 frames a few times now and its same black frame across the entire sequence. It seems that I am not manipulating the right thing. :( I am still learning Cycles my self since I've mainly used the old renderer up until this point since I didn't really have any reason to switch. Perhaps someone more experienced with cycles can help.
https://linustechtips.com/topic/454117-blender-rendering-issues/#findComment-6111614
Dang! Well, I really appreciate the help. I might just start fresh and see what happens.
Again, thanks for taking the time!
https://linustechtips.com/topic/454117-blender-rendering-issues/#findComment-6114300
I had a look to and yeah i have no idea. I would move to cycles as blender render (lol) is actually not being development.
                     ¸„»°'´¸„»°'´ Vorticalbox `'°«„¸`'°«„¸
`'°«„¸¸„»°'´¸„»°'´`'°«„¸Scientia Potentia est  ¸„»°'´`'°«„¸`'°«„¸¸„»°'´
https://linustechtips.com/topic/454117-blender-rendering-issues/#findComment-6115536
Happy to help. (or at least attempt to.) I think a fresh start is probably your best bet at this point.
https://linustechtips.com/topic/454117-blender-rendering-issues/#findComment-6115815
