What setting should i set my D5 to?
It goes through over 10ft of tubing, has a height change of about 4 feet, a XSPC raystorm CPU block, and a HD7950 with EK waterblock, and a magicool dual 180mm Rad
https://linustechtips.com/topic/453496-what-pump-speed/
Most times you can get away with putting it on the lowest setting but since you have such a long run maybe 50% or 25%, best is to see the flow rate back to the res if it's really really low then increase it to a reasonable level.
https://linustechtips.com/topic/453496-what-pump-speed/#findComment-6082676
Most people just set theirs to 3, maybe go 4 if you like. It wont really matter too much, water will find its way through.
[Case Mod] Operation: The Division --- > Here
[CUSTOM WATER COOLED TABLE] Project: Ravage ---> Here
-== QUOTE ME IN YOUR REPLY IF YOU WANT ME TO RESPOND ==-
https://linustechtips.com/topic/453496-what-pump-speed/#findComment-6082679
I cant see the flow in my res, it just looks still, it always has.
https://linustechtips.com/topic/453496-what-pump-speed/#findComment-6082691
I have a D5 with a good amount of resistance. 2 GPUs, CPU, 2 rads, and I always set it on 3. You could get away with setting it anywhere from 2-4.
Case Phanteks Enthoo Evolv ITX | Motherboard Asus ROG Strix Z270i | CPU Intel i7-7700K | RAM Team Vulcan 16GB DDR4 | GPU Geforce GTX 1080 Ti | Storage Crucial MX300 1TB M.2 | PSU Corsair RM750x
https://linustechtips.com/topic/453496-what-pump-speed/#findComment-6082696
Best is to check temps if you notice them going higher and higher you probably have a flow issue, sometimes it's fairly obvious when the water level is low and there is very little turbulence on the inlet side of the res then there's most likely an issue with the length of the run and the amount of resistance.
https://linustechtips.com/topic/453496-what-pump-speed/#findComment-6082724
Ok, ill try that.
Right now my load temps are only like 42, but its semi loud.
Though ATM it doesnt matter, at least not until i get a waterblock for GPU.
https://linustechtips.com/topic/453496-what-pump-speed/#findComment-6082763
Ok, ill try that.
You should be good though even having it less than half the full speed the D5 is a pretty beast pump.
https://linustechtips.com/topic/453496-what-pump-speed/#findComment-6082773
Ok.
Good, as in my home theater cabinet, i have the hoses going up and down a large amount of space.
Now I just need my GPU with waterblock im getting soon, then my PC will be virtualy silent, as the D5 pump is closed in a cabinet.
Maby some noise dampening foam too.
https://linustechtips.com/topic/453496-what-pump-speed/#findComment-6082796
I can't see what setting mine is on with it mounted but I just used a bit from a screw driver and turn it down in till I literally couldn't hear anything from my pump which was something like 2460 rpm according to the reading from my motherboard, then I put my side panel back on and haven't looked back.
Case - NZXT H6 Flow : Mobo - ASRock X670E PG Lightning : PSU - Deepcool PX1000G : CPU - AMD Ryzen 9 7900X3D w/Arctic Freezer III 360  : Memory - G.Skill Ripjaws S5 32gb 6000mhz CL30 : GPU - MSI Expert 4080 Super : Storage - Verbatim Vi7000G 4tb NVME SSD  : Displays - Gigabyte 32" M32QC Curved 165hz & 27" M27Q Pro 165hz 1440p
https://linustechtips.com/topic/453496-what-pump-speed/#findComment-6093784
3.5 is the sweat spot.
Seems the best for me atm, my pump vibrates too much to have on full, the noise pisses me off.
Chernobyl
AMD FX8350 @ 5GHz | Asus Sabretooth 990FX R2 | 16GB HyperX Savage @1950mhz CL9 | 120GB Kingston SSDNow
EK AMD LTX CSQ | XSPC D5 Dual Bay | Alphacool NexXxoS XT45 240mm & Coolgate Triple HD360
Kraken
Intel i5 4670K Bare Die 4.9GHz | ASUS Maximus VII Ranger Z97 | 16GB HyperX Savage 2400MHz | Samsung EVO 250GB
EK Supremecy EVO & EK-MOSFET M7G  | Dual 360mm Rads | Primochill CTR Phase II w/D5 | MSI GTX970 1670MHz/8000MHz
Graphic Design Student & Overall Nerd
https://linustechtips.com/topic/453496-what-pump-speed/#findComment-6095251
