Sennheiser HD 800 /sarcasm.
Any quality headphones will serve you very well. And if you want to you can set up Razer Surround for virtual surround sound
Nova doctrina terribilis sit perdere
Audio format guides: Vinyl records | Cassette tapes
https://linustechtips.com/topic/45218-positional-audio/#findComment-594185
I really liked my HD595's for gaming, the current iteration is the HD598,
you could go HD558 and try the foam mod, and get something that is supposed to sound like 598's
Will work for electronic components and parts
Reviews: Meelec CC51P - Monoprice 8323 - Koss Porta Pros  - Shure SRH-440 - Shure SRH-550DJShure SRH-840 - Hifiman He-500 - iBasso D4 - o2 Amplifier  -  SkeletonDac
https://linustechtips.com/topic/45218-positional-audio/#findComment-597798
