Need help with cpu cooler.
Go to solution Solved by WoodenMarker,
Budget - the cheaper the better .... +- 120
Could you give both water and air?
Some build details:
CASE: NZTX S340.
GPU: KFA2 GTX 970 EXOC Black
PSU: 750W
MOBO: msi z97s sli krait edition
If you're just going for looks, there isn't much that compares to an ETS-T40-BK with AF120 QE's with the white ring.
http://pcpartpicker.com/part/enermax-cpu-cooler-etst40bk
http://pcpartpicker.com/part/corsair-case-fan-co9050001ww
Here it is in a friend's system:
Can someone sudgest cooler for 4690k?
Sound- don't care
Color - dark( mobo is msi krait)
Don't suggest noctua.... hate their design.
Budget? Air or Water?
Dark Rock Pro 3!
Follow the topics you create using the "Follow" button in the top right corner!
One day I will have my GTX 970. One day. PC specs are at my profile.
Not sure how to check what part works with what? Check out my compatibility guide!
Dark rock looks nice...from the side, top looks like a ugly metal box(more interested in esthetic then performance) problem is with this cooler i cant use different fans, and mounting it is realy hard.... i have quite high profile ram.
I'd say the best option is something made by Be Quiet!, or possibly the black version of the Phanteks PH-TC12DX, as the white-framed fans on that should fit the Krait colour scheme quite well.
Main Rig "Melanie" (click!) -- AMD Ryzen7 1800X • Gigabyte Aorus X370-Gaming 5 • 3x G.SKILL TridentZ 3200 8GB • Gigabyte GTX 970 G1 Gaming • Corsair RM750x • Phanteks Enthoo Pro --
HTPC "Keira" -- AMD Sempron 2650 • MSI AM1I • 2x Kingston HyperX Fury DDR3 1866 8GB • ASUS ENGTX 560Ti • Corsair SF450 • Phanteks Enthoo EVOLV Shift --
Laptop "Abbey" -- AMD E-350 • HP 646982-001 • 1x Samsung DDR3 1333 4GB • AMD Radeon HD 6310 • HP MU06 Notebook Battery • HP 635 case --
Some build details:
CASE: NZTX S340.
PSU: 750W
looks  realy nice.
forgot  to add that i  run RGB lighting in my case(black s340) and Xigmatek XAF-F1255(back)/ XAF-F1253(front)
how  is  this coolers performance?
i am not  in to  liking  of  white  fans.....
i am curently  runing xigmatek XAF-F1255(back)/ XAF-F1253(front, had  them from old system, saw  no point  to  buy  new  :D) fans.
my  case nzxt itself  is  black
In that case I'd go for a Be Quiet! cooler.
