http://pcpartpicker.com/p/jLRVvK
I am not a hardcore gamer but i do like to play games like World of Warships and i want a setup to play on low to medium settings and i would like to keep it within the $600 range so if you know of a way to improve anything or make it cheaper please help
Thanks
https://linustechtips.com/topic/451184-my-first-build/
Motherboard: MSI Z97 PC MATE ATX LGA1150 Motherboard  ($87.75 @ OutletPC)
Video Card: Sapphire Radeon R9 285 2GB ITX COMPACT OC Video Card  ($172.98 @ Newegg)
Case: Thermaltake Core V41 ATX Mid Tower Case  ($54.70 @ Newegg)
Operating System: Microsoft Windows 7 Home Premium SP1 OEM (64-bit)  ($86.75 @ OutletPC)
Total: $603.92
Generated by PCPartPicker 2015-09-16 19:14 EDT-0400
#G3258 HYPE TRAIN
My rig: Intel Core i7-8700K OC 4.8 | NZXT Kraken X62 | ASUS Z370-F | 16 GB Trident Z RGB 3000 (2x8) | EVGA 1070 SC | EVGA SuperNova NEX650G1 | NZXT H700 | Samsung 250GB 850-EVO | 2x 2TB Seagate Barracuda HDDs
https://linustechtips.com/topic/451184-my-first-build/#findComment-6049572
CPU: Intel Core i3-4160 3.6GHz Dual-Core Processor  ($112.89 @ OutletPC)
Motherboard: ASRock H97M Anniversary Micro ATX LGA1150 Motherboard  ($67.89 @ OutletPC)
Video Card: XFX Radeon R9 270X 2GB Double Dissipation Video Card  ($179.99 @ SuperBiiz)
Case: Cooler Master N200 MicroATX Mid Tower Case  ($43.99 @ NCIX US)
Power Supply: EVGA 600B 600W 80+ Bronze Certified ATX Power Supply  ($59.99 @ Newegg)
Operating System: Microsoft Windows 10 Home OEM (64-bit)  ($97.89 @ OutletPC)
Total: $651.52
Generated by PCPartPicker 2015-09-16 19:15 EDT-0400
you want a great gpu if you wanna game
Rigs I've Built
The Striker i5 4590 @ 3.7 ||  MSI GTX 980 Armor X2 || Corsair RMX 750 || Team Elite Plus 8 GB || Define S || MSI Z97S SLI Krait
The Office PC i3 4160 @ 3.6 || Intel 4600 || EVGA 500B || G.Skill 8 GB || Cooler Master N200 || ASRock H97M Pro4
The Friend PC G3258 @ 4.3 || Sapphire R9 280X Tri-X || EVGA 600B || 8 GB Dell Ram || Cooler Master N200 || ASRock H97M- iTX/ac
The Mom Gaming PC A10-7890K @ 4.4 || iGPU + ASUS R7 250 ||  8 GB Klevv DDR3-2800 Mhz
https://linustechtips.com/topic/451184-my-first-build/#findComment-6049578
Total: $603.92
#G3258 HYPE TRAIN
please dont use the g3258, cause it will bottleneck most mid range cards (960 and up) and 2 cores is not enough for modern gaming
Rigs I've Built
https://linustechtips.com/topic/451184-my-first-build/#findComment-6049581
http://pcpartpicker.com/p/6LGJ3C
A gpu is very important (probably the most important for gaming. try this...
My rig: r7 1700 @ 3.9/1.35v, 16gb ddr4 3200, assorted rando SSDs, hx 1050, vega 64 1650/1025
MY $75 BUILD https://linustechtips.com/main/topic/576889-the-75-build-log/#comment-7547280
https://linustechtips.com/topic/451184-my-first-build/#findComment-6049583
You could just use the stock cooler on a locked chip and save some money there
USEFUL LINKS:
PSU Tier List F@H stats
https://linustechtips.com/topic/451184-my-first-build/#findComment-6049601
That's why there's a 285. I have a 280 and it's pretty good so a 285 should do pretty well also, despite having less vram. Most games don't even take advantage of more than one or two cores, so the CPU should be aig't and not too hot w/ a mild OC.
https://linustechtips.com/topic/451184-my-first-build/#findComment-6049603
its a tray proccessor and doesnt come with a stock cooler
https://linustechtips.com/topic/451184-my-first-build/#findComment-6049611
ut the fact being that stuttering and minimum fps is terrible on dual cores in most modern games. the stuttering combined with the horrible minimum fps pretty much kill the g3258 from playing games like gta v, far cry 4, shadow of mordor, etc.even though the gpu can run them
Rigs I've Built
https://linustechtips.com/topic/451184-my-first-build/#findComment-6049890
CPU: AMD FX-6300 3.5GHz 6-Core Processor  ($96.89 @ OutletPC)
Motherboard: Asus M5A78L-M/USB3 Micro ATX AM3+ Motherboard  ($47.99 @ SuperBiiz)
Video Card: Sapphire Radeon R7 370 2GB Dual-X Video Card  ($153.98 @ Newegg)
Case: NZXT Source 210 (Black) ATX Mid Tower Case  ($35.99 @ SuperBiiz)
Total: $576.97
Generated by PCPartPicker 2015-09-16 20:09 EDT-0400
#AMD MASTER RACE
https://linustechtips.com/topic/451184-my-first-build/#findComment-6049990
@007agentHP do u have a build suggestion
look at the 6th post down. mine is there
Rigs I've Built
https://linustechtips.com/topic/451184-my-first-build/#findComment-6049998
Total: $576.97
#AMD MASTER RACE
an fx? really?  the i3 in my build and the 270x will kill it. the fx series is still filled with terrible fps drops even showcased on this forum. and the i3 has a upgrade path to an i7.
Rigs I've Built
https://linustechtips.com/topic/451184-my-first-build/#findComment-6050013
@007agentHP i will most likely build the system without the video card and after i would buy a video card and i would be willing to spend more on it so can u give 2 or 3 choices for a low medium and high tier
r9 270x for low mid tier $150
r9 280x mid tier for $220
and a r9 390 for high tier  $300
Rigs I've Built
https://linustechtips.com/topic/451184-my-first-build/#findComment-6050209
