Well i was wondering what you guys prefer when it comes to builds, and cases, do you prefer a micro atx case that still has all the features as in watercooling such as the 350D, or would you rather get something that you could throw in a regular atx board in down the line or even a Extended atx down the line? what do you prefer overall?
https://linustechtips.com/topic/45089-micro-atx-vs-atx/
The benefits aren't that great anymore. My old LianLi ATX case is smaller on the outside than many mATX cases you can buy these days. I prefer compact ATX cases over roomy mATX.
exacly that. some atx case (cm 361, node 605) are smaller than mitx cases these days ... looking at you prodigy...
and i m currently using 7 slots on my board with 1 expension card i can t use , because my case can t take 8...
Anything I write is just a comment, take is as such, there is no guarantees associated with anything I say.
ATX Portable rig (smaller than prodigy(LOL)) :  Nmedia 2800 | Gigabyte Z77x-ud3h  | Corsair HX1000 | Scythe Big Shuriken | i5 3570K  |  XFX R9 290 DoubleD | Corsair Vengeance 32GB
https://linustechtips.com/topic/45089-micro-atx-vs-atx/#findComment-592944
The reason i'm going with a micro atx build is because that's the only way i can have a really nice looking 900D esk case without shelling out 300 dollars.
https://linustechtips.com/topic/45089-micro-atx-vs-atx/#findComment-594472
I think all motherboard sizes serve their purpose, but I personally would prefer having a full system with all of my extra cards, or a compact machine with an ITX board. The only problem with ITX is that onboard sound is not to the point where i feel it needs to be; at the same time I do have an external mix-amp for my headphones so problem solved. :p
https://linustechtips.com/topic/45089-micro-atx-vs-atx/#findComment-594492
