Can anyone find the full tech specs ( such as the graphics processor, codec, specs of processor) For the Panasonic palmcorder IQ pv-A386
http://www.manualslib.com/manual/507078/Panasonic-Palmcorder-Iq-Pv-A306.html?page=33#manual
Wasn't exactly difficult to find a manual. Google brought it up as the first result.
Anything more detailed than that however isn't easy to find, so if you're looking for schematics or anything they aren't as easy to dig up.
The New Machine: Intel 11700K / Strix Z590-A WIFI II / Patriot Viper Steel 4400MHz 2x8GB / Gigabyte RTX 3080 Gaming OC w/ Bykski WB / x4 1TB SSDs (x2 M.2, x2 2.5) / Corsair 5000D Airflow White / EVGA G6 1000W / Custom Loop CPU & GPU
The Rainbow X58: i7 975 Extreme Edition @4.2GHz, Asus Sabertooth X58, 6x2GB Mushkin Redline DDR3-1600 @2000MHz, SP 256GB Gen3 M.2 w/ Sabrent M.2 to PCI-E, Inno3D GTX 580 x2 SLI w/ Heatkiller waterblocks, Custom loop in NZXT Phantom White, Corsair XR7 360 rad hanging off the rear end, 360 slim rad up top. RGB everywhere.
https://linustechtips.com/topic/450748-tech-specs/#findComment-6043654
