To start it out, you are looking at something like an i5 4670, 8 gigs of RAM, and say a GTX 760 or Radeon 7950. With that you will need to pick a motherboard, case, and I would say a 500-650 watt power supply. Might leave just a few bucks left over for a SSD ;)
Also someone was willing to see me this for $750
is it a rip off or...?
Specs:
-Intel i3 3220 (acts as quad core in games)
-MSI B75MA-E33 motherboard
-Power Color 7870 2gb (Tahiti LE, same as 7950!)
-2x2GB G.Skill Trident RAM 1600mhz
-Eco h60 Liquid Cooling
-400watt Silencer Mk iii 80+ modular PSU
-Asus DVD drive/burner
-500GB 7200RPM Samsung HDD
-NZXT Source 210 Elite
-Also added 1x NZXT 140mm top fan, and 1x NZXT 120mm white LED radiator fan
-Windows 8 64-bit
it's slightly over your budget($10), but this would be my recommendation. http://pcpartpicker.com/p/1qVX6
Do you need OS or peripherals?
Specs:
-Windows 8 64-bit
use the stock cooler
<p>Wires Suck :angry:
!fY0|_|(4|\|R34[)7#!5PMM37#3(0[)3:1337 70833|\|73R3[)!|\|49!\/34\|/4Y 4|\|[)93741!f3
Specs:
-Windows 8 64-bit
rip off
the i3 acts like a dual core in gaming hyperthreading never used in games really
the 7950 can be gotten for cheaper than a 7870 xt
you want 8gb of ram
the eco h60 isn't all that great of a cooler
that psu is so-so
a 1tb drive is pretty cheap these days
http://pcpartpicker.com/p/1qW3d
Might end up being a bit too much once you put a nice case and hhd/ssd in there. but you can get a cheaper motherboard, or go the AMD route.
Also, you can find a 7950 for cheaper than that price in the link.
Less efficient. It will use more power out of the wall to make the same amount of power to the components of the computer. Basically not as good quality, but its not a very big difference. The BEST you will ever see is about 92% efficient, where a bronze is still over 80%.
What he said^
You don't need it. It's more of a marketing ploy that they say bronze, silver, etc. instead of just putting the efficiency in numbers.
Is the budget just for the tower? Do you need a copy of Windows?
Read this: http://linustechtips.com/main/topic/3061-build-plan-thread-reccomendations-please-read-before-posting/
Answer some of the questions and add any info you want. It helps us help you. :)
I would put forward all the money into the tower in the initial build.
run ubuntu on it and hook it up to an old lcd and ps2 keyboard and mouse sitting in the corner. Then work your way up
Desk
chair
Monitor
Windows
Mouse
Keyboard
Then your set in about 5 months
I would like to point out that I sold my bed to even afford my rig...
been sleeping on the floor ever since and it was worth it
https://www.youtube.com/watch?v=HhGjPuNXHOo&feature=c4-overview&list=UUNucC7z-NhjhVg3R81Ud3MQ
Heres video proof that I sold my bed
#KilledMyWife
LTT's Resident Black Star
I should get an award for still being here at this point
