Hey guys, I put together this ( http://pcpartpicker.com/p/ZQK4Lk ) Gaming PC build on PC PART PICKER, My question is
Does my motherboard support WI-FI , Not ethernet. I don't have a router close to my bedroom and I was wondering If my motherboard supports WI-FI
If it does NOT , Please leave a better board with WI-FI that does NOT exceed the 60$ mark...
OR!
Leave a WI-FI Adapter ( Usb perfered ) , Link because I know they're cheaper.
OR
If you have an OVERALL better build for me to buy/look at, Please do.
EVERYTHING MUST ADD UP TO NOT GO OVER THE $515 MARK!
https://linustechtips.com/topic/450250-need-help/
CPU: AMD FX-6300 3.5GHz 6-Core Processor  ($97.89 @ OutletPC)
Motherboard: MSI 760GMA-P34(FX) Micro ATX AM3+ Motherboard  ($49.99 @ SuperBiiz)
Storage: Sandisk SSD PLUS 120GB 2.5" Solid State Drive  ($41.99 @ NCIX US)
Video Card: MSI GeForce GTX 950 2GB Video Card  ($149.99 @ SuperBiiz)
Case: Cooler Master N200 MicroATX Mid Tower Case  ($43.99 @ NCIX US)
Power Supply: EVGA 400W ATX Power Supply  ($29.98 @ OutletPC)
Wireless Network Adapter: Gigabyte GC-WB867D-I 802.11a/b/g/n/ac PCI-Express x1 Wi-Fi Adapter  ($29.99 @ SuperBiiz)
Total: $511.20
Generated by PCPartPicker 2015-09-15 00:59 EDT-0400
950 is  much much better than the 750ti for that price and unless you tried to get a 270 or 280 something used its probably your best bet at the price point.
I really don't like recommending either 120 GB ssd's or amd 6300's but at this price point its pretty much all you can get. I hope however you have the ability to grab a random HDD from an old computer sitting around.
LINK-> Kurald Galain:  The Night Eternal
Top 5820k, 980ti SLI Build in the World*
CPU: i7-5820k // GPU: SLI MSI 980ti Gaming 6G // Cooling: Full Custom WC //  Mobo: ASUS X99 Sabertooth // Ram: 32GB Crucial Ballistic Sport // Boot SSD: Samsung 850 EVO 500GB
Mass SSD: Crucial M500 960GB  // PSU: EVGA Supernova 850G2 // Case: Fractal Design Define S Windowed // OS: Windows 10 // Mouse: Razer Naga Chroma // Keyboard: Corsair k70 Cherry MX Reds
Headset: Senn RS185 // Monitor: ASUS PG348Q // Devices: Note 10+ - Surface Book 2 15"
LINK-> Ainulindale: Music of the Ainur
Prosumer DYI FreeNAS
CPU: Xeon E3-1231v3  // Cooling: Noctua L9x65 //  Mobo: AsRock E3C224D2I // Ram: 16GB Kingston ECC DDR3-1333
HDDs: 4x HGST Deskstar NAS 3TB  // PSU: EVGA 650GQ // Case: Fractal Design Node 304 // OS: FreeNAS
https://linustechtips.com/topic/450250-need-help/#findComment-6036425
Ima go another route again, and say, go for an APU build with a nice cooler, and 2400mhz RAM, and say save up and shoot for like a 390 GPU in the future, so overall it'll perform somewhere in the range of that 750ti build, but it will have DX12 support I believe so in the near future it may better, I gotta check on that more.
http://pcpartpicker.com/p/DmcqZL
Mainly the ITX board comes with a wifi/bluetooth chip, totals about 500 bucks
PC part picker lists the case as incompatible, but the 120xl cooler should fit in it and be fairly silent.
http://community.coolermaster.com/index.php/topic/12330-elite-130-nepton-120xl/
https://linustechtips.com/topic/450250-need-help/#findComment-6036492
