Hey guys I am planning a new build I am not sure when I'm going to build it yet.
My goal for the build is to have a really small form factor portable PC which I can take anywhere with me. The only games it needs to run are CS:GO, Portal 2, or GTA San Andreas
I am not sure on budget I am asking for build lists to get an idea of the costs. It doesn't need a monitor or peripherals.
Thanks in advance
https://linustechtips.com/topic/450203-mini-itx-light-gaming-build/
How small is small? R9 Nano small or like a case that can barely fit a 980Ti?
CoolerMaster Elite 110 or Corsair 250D? Something like that,
i7-6700k  Cooling: Deepcool Captain 240EX White GPU: GTX 1080Ti EVGA FTW3 Mobo: AsRock Z170 Extreme4 Case: Phanteks P400s TG Special Black/White PSU: EVGA 850w GQ Ram: 64GB (3200Mhz 16x4 Corsair Vengeance RGB) Storage 1x 1TB Seagate Barracuda 240GBSandisk SSDPlus, 480GB OCZ Trion 150, 1TB Crucial NVMe
(Rest of Specs on Profile)
Something around the size of a CM Elite 110, here is a part list I made. Is this good? Please make sure you use AUD prices when making one.
CPU: Intel Pentium G3258 3.2GHz Dual-Core Processor  ($89.00 @ Centre Com)
Motherboard: Gigabyte GA-B85N Mini ITX LGA1150 Motherboard  ($95.00 @ CPL Online)
Memory: Corsair 4GB (1 x 4GB) DDR3-1600 Memory  ($35.99 @ Mwave Australia)
Video Card: Gigabyte GeForce GTX 750 Ti 2GB Video Card  ($165.00 @ Umart)
Power Supply: SeaSonic 450W 80+ Gold Certified Semi-Modular ATX Power Supply  ($108.95 @ Mwave Australia)
Total: $611.94
Generated by PCPartPicker 2015-09-15 13:07 AEST+1000
500 ish dollars, A10 7870k with 2400mhz ram and a 120xl cooler, feel free to drop the cooler and save some money if the budget is lower, I had the build lying around.
http://pcpartpicker.com/p/DmcqZL
Get a case with a PSU already in it, perhaps try to look for a barebones or premade pc for cheap and slap a 750 ti in it.
You're not asking to run very demanding games, but I would suggest at least 8gb of ram, 4gb is just a headache to use.
Here's a build I made for you. The case is really up to you, you can spend up to $100 on it. I went with a smaller HDD, since the games you listed aren't large, and this will be your 'lan box'.
Motherboard: ASRock H97M Anniversary Micro ATX LGA1150 Motherboard  ($67.89 @ OutletPC)
Memory: Team Elite 8GB (1 x 8GB) DDR3-1600 Memory  ($35.99 @ Newegg)
Video Card: MSI GeForce GTX 750 Ti 2GB Video Card  ($124.83 @ SuperBiiz)
Power Supply: EVGA 400W ATX Power Supply  ($29.98 @ OutletPC)
Total: $388.56
Generated by PCPartPicker 2015-09-15 12:44 EDT-0400
You can always swap the games on the HDD. You might want dual channel ram, that's up to you, but with 1 stick you can upgrade later.
This MOBO, cooler, and CPU can overclock so you're good to go with that, but keep the PSU at 400w+.
A Smaller case will take an SFX PSU, so maybe if you go that route, get PSU + case combo.
The GPU i selected is the very same I use and this card IS TINY. It's a single slot card that be used at half height!
