Hi guys, I want to build a pc in this website (www.chiptec.net).
My budget is about 1000€ and I want to build a pc that can max out games at 1080p60 while recording and also be able do render "fast". Should I go for a xeon because of hyperthreading, once I have a dedicated gpu ? Should I pay a bit more and get an i7, will that fit on the budget ? Should I go for an i5 with a nice oc ? What should I do ? What should I buy? And what about a GPU?!?! 970 ? 390?
What about the rest of the build ? Can I still get an ssd ? What chipset should I buy ?
I would be very greatfull if u could spend some time building a pic for my need in this site www.chiptec.net
https://linustechtips.com/topic/450082-what-cpu-should-i-go-for/
Honestly with a 1000€ budget, if you want to incorporate a nice, balanced GPU as well, your best bet would be a Xeon with a 390 in my opinion. Pair it with an H81/87 motherboard and a solid 8-16GB kit of 1600/1866MHz RAM and you have yourself a very balanced, 1080p/60fps setup for a solid few years that can render, stream, record and game with no issues.
Cinders: - i7 4790K (4.5GHz) - Gigabyte Z97X-SOC - 16GB Klevv DDR3 1600MHz - EVGA GTX 980Ti ACX2.0+ (1548MHz Boost) - EVGA Supernova 850GS - NZXT H440 Orange/Black (Modified) -
Unnamed System: i5 4690K (4.2GHz) - MSI Z97I-AC - 8GB G.Skill DDR3 2400MHz - EVGA GTX 950 SSC - Raidmax Thunder V2 535W - Phanteks Enthoo Evolv ITX
https://linustechtips.com/topic/450082-what-cpu-should-i-go-for/#findComment-6034386
Skyline is better, Haswell is better bang for the buck. It comes down to your priorities and budget.
If your going skyline I would recommend going for the core i5 6600k
SkyLAKE
https://linustechtips.com/topic/450082-what-cpu-should-i-go-for/#findComment-6034390
If youre streaming and rendering definitely go for something with 8 threads,
the 8350 etc. would actually be a possibility here, but you are probably still better of with a e3 1231v3 and a budged motherboard.
mobo+ cpu is about 300-350
970/390 is about 300-350
That leaves enough space for an ssd and the rest
https://linustechtips.com/topic/450082-what-cpu-should-i-go-for/#findComment-6034402
Not in that store, here in Portugal we pay a lot more for what we get. Those are the problems of €
https://linustechtips.com/topic/450082-what-cpu-should-i-go-for/#findComment-6034453
Auto correct, usually catch it but they slip through sometimes.
Just seeing two people say it irked me, idk why lol. My bad, should've figured it was something like that.
https://linustechtips.com/topic/450082-what-cpu-should-i-go-for/#findComment-6034543
Mhh, I cant really look at the portuguese sites but there should be some that sell a 1230v3 or a 1231v3 for a reasonable price.
If everything is expensive you could even order everything somewhere else in the eu, Mindfactory has good prices and ships for 29 euro. (1231v3 costs 250 there).
https://linustechtips.com/topic/450082-what-cpu-should-i-go-for/#findComment-6034561
Gotta love them Skyline processors LOL
https://linustechtips.com/topic/450082-what-cpu-should-i-go-for/#findComment-6034567
