So when i turn minecraft into a game with AA though mcpatcher it looks something like this.9dplv.png
Are there any fixs for this.
Listen if you care.
https://linustechtips.com/topic/44987-minecraft-with-aa-issues/
Right click desktop > Personalize > Display, make sure ur display is set to 100%
Yep its maxed at 1680x1050. Cant go any higher.
Listen if you care.
https://linustechtips.com/topic/44987-minecraft-with-aa-issues/#findComment-590787
Why wont you turn AA off?
We are gamers, gamers dont give up.
Listen if you care.
https://linustechtips.com/topic/44987-minecraft-with-aa-issues/#findComment-590791
a real gamer plays on a Super high end gaming rig at the lowers possible settings with AA maxed out... that way he can see all of the enemy movements and doesnt get frame rate lagg... i used to do that with a 120hz screen when i was sponsored by BenQ
Character artist in the Games industry.
https://linustechtips.com/topic/44987-minecraft-with-aa-issues/#findComment-590806
thats resolution. should get something like this:
100% all the way, its weird when i make things bigger.
Listen if you care.
https://linustechtips.com/topic/44987-minecraft-with-aa-issues/#findComment-590869
make sure ur GPU is set to quality not performance
Ive not even touched the catalyist control with my current gpu, im sure the default setting arent causing this, some searching around shows that this happens to amd cards for some reason and then wandows has some compatibility issues. Ive giving this issue 30 minutes, if its not solves then its going to the naughty corner.
Listen if you care.
https://linustechtips.com/topic/44987-minecraft-with-aa-issues/#findComment-590904
default is usualy performance... switch it over to quality
https://linustechtips.com/topic/44987-minecraft-with-aa-issues/#findComment-590905
Sometimes its too hard to continue even if you are enthousiast.
Have you updated your drivers?
https://linustechtips.com/topic/44987-minecraft-with-aa-issues/#findComment-590923
default is usualy performance... switch it over to qualityI
Its working now yay, turns out that my gpu is trying to force AA and the java script is forcing the AA to turn off. The two go pissed and removed a line where the AA is. Just go into the ini file, sort it out manually.
Listen if you care.
https://linustechtips.com/topic/44987-minecraft-with-aa-issues/#findComment-590924
Disable AA for minecraft in the config of your GPU and you should be good to go.
Source: http://www.minecraftforum.net/topic/964617-looks-horrible-pink-lines-between-blocks/
AMD Phenom II x4 955 - Gigabyte GA-870A-UD3 - XFX HD7870 CORE - 60 GB OCZ Agility 3 - 1 TB Western Digital Green - 1 TB Hitachi DeskStar
OCZ ModXstream 600W - 16 GB Corsair XMS3 - Cooler Master HAF 912 Plus - Logitech G110 - Speedlink Kudos - Sennheiser HD 518
Steam The reason I am still alive Dark Theme
https://linustechtips.com/topic/44987-minecraft-with-aa-issues/#findComment-595988
Its working fine now
Listen if you care.
https://linustechtips.com/topic/44987-minecraft-with-aa-issues/#findComment-596073
I haven't played minecraft since alpha but why would you want AA on a game like minecraft, maybe that's just me.
the game is littered with jaggies. i dont mind the blockiness of the game but its nice to have a straight edge.
Listen if you care.
https://linustechtips.com/topic/44987-minecraft-with-aa-issues/#findComment-596150
It might just be me because the last time i played the game was when there wasn't really a graphics menu of any kind, too bad i lost my info for my old email that was connected to my minecraft account.
https://linustechtips.com/topic/44987-minecraft-with-aa-issues/#findComment-596165
You used the hackish way, but know the GPU actually support to do it without ini tinkering.
https://linustechtips.com/topic/44987-minecraft-with-aa-issues/#findComment-596421
What about the people who turn all the settings up as high as their computer con reasonably run them and use a 6ohzz IPS monitor because a gorgeous looking game gives them more immersion?
Are they not "real gamer(s)" ???
Case: Corsair C70 GunMetalBlack, CPU: Intel 3570k, Mobo: Asus p8z77-v lx, CPU Cooler: BeQuiet! Dark Rock Pro 2, RAM: 8GB Corsair Vengeance 1600Mhz lp, Video Card: Asus HD7950 DC2 Top V2, SSD: Samsung 840 pro, HDD: one Seagate 2TB Barracuda, PSU: BeQuiet! Dark Power pro 10 650w, Monitor: Dell UltraSharp u2412m, Keyboard: CoolerMaster QuickFire tk (Brown Switches), Mouse: Steelseries Sensei raw, Sennheiser HD 558
https://linustechtips.com/topic/44987-minecraft-with-aa-issues/#findComment-598315
I think this also was some kind of bug in MCPatcher, I had it, deleted the .jar en patched again with newest MCPatcher. Problem gone
Ryzen 7 5800X     Corsair H115i Platinum     ASUS ROG Crosshair VIII Hero (Wi-Fi)     G.Skill Trident Z 3600CL16 (@3800MHzCL16 and other tweaked timings)
MSI RTX 3080 Gaming X Trio    Corsair HX850     WD Black SN850 1TB     Samsung 970 EVO Plus 1TB     Samsung 840 EVO 500GB     Acer XB271HU 27" 1440p 165hz G-Sync     ASUS ProArt PA278QV     LG C8 55"     Phanteks Enthoo Evolv X Glass     Logitech G915      Logitech MX Vertical      Steelseries Arctis 7 Wireless 2019      Windows 10 Pro x64
https://linustechtips.com/topic/44987-minecraft-with-aa-issues/#findComment-599552
