I'm currently rocking a GTX 550ti and this thing simply isn't able to give me a good performance on high settings. It will also be destroyed by next-gen games so I'm just looking for a card that will give great performance for the price and will be able to play BF4, Watch Dogs, etc. My processor is a i5-3570k
Currently the 7970 is $320. Is that a good buy?
-Thanks for the help
https://linustechtips.com/topic/44949-best-graphics-card-for-400/
At the moment, probably a 7950. I would wait for the 9000 series though.
Edit: Where the hell is this 7970? They are super expensive over here.
https://linustechtips.com/topic/44949-best-graphics-card-for-400/#findComment-590131
Those have been rumored to be released or at least to be spoken about in September right?
It should be around at the end of September - October time.
https://linustechtips.com/topic/44949-best-graphics-card-for-400/#findComment-590155
According to Elric the 9xxx series will be released on September 25th.
CPU: i5 4690K  CPU Cooler: Corsair H100   Motherboard: Gigabyte Z97X UD3H   Memory: G.Skill (2 x 4GB) DDR3-1866   Storage: Samsung 830 Series 128GB 2.5" SSD/Seagate Barracuda 1TB 3.5" 7200RPM   GPU: EVGA GeForce GTX 660 Ti SC 2GB   Case: Cooler Master CM 690 II (Black) ATX Mid Tower   PSU: CORSAIR Enthusiast Series TX650M 650W 80 PLUS BRONZE Certified   Optical Drive: MSI DH-24AAS-17 R DVD/CD Writer   Operating System: Windows 10 Pro (64 bit)
https://linustechtips.com/topic/44949-best-graphics-card-for-400/#findComment-590189
I personally expect AMD to release two cards, one around the $549-$499 price range and another around the $449-$399 price range.
So waiting might be a good idea, a 7970 for 320 dollars is still a brilliant buy though & that's what I'd recommend.
https://linustechtips.com/topic/44949-best-graphics-card-for-400/#findComment-590225
A good 7970 is the around the same price as a good 770 and considering when you buy from zotac you get 3 free games. Plus nvidia gives an extra 2 games free. And spare 50 extra money's for 4gb semi future proofing.
PRIMARY NVIDIA PC
("I'm a Fanboy of Everything")
| CPU - i5-4670K @ 4.8ghz | CPU Cooler - Antec Kühler H2O 620 | GPU(S) - BIOS MODDED Twin GTX 770 4gb (Gigabyte)-master (Zotac)-slave @ 1337/2000 (8000 Effective) | Mobo - MSI Z87 GD65 Gaming | PSU - Corsair TX850M | Ram - 8gb Gskill RipjawsX @ 1866Mhz | Monitor - Samsung 27" 550 1080p 75Hz | Keyboard - Razer Black-Widow Ultimate 2013 | Storage - 2x 1TB WD-Blacks' | Mouse - AzzA Mouse Would Say "SQUEEKSQUEEK"|
SECONDARY RADEON PC
| CPU - A10-6800K @ 4.6ghz | CPU Cooler - CM Hyper EVO 212 | GPU(S) Twin Radeon 270x 2gb @ 1115/1500 (6000 Effective) | Mobo - MSI FM2-A85XA-G65 | PSU - Logisys 750W | Ram - 8gb @ 1600mhz | Moniter - Acer 24'' 1080p 60Hz
https://linustechtips.com/topic/44949-best-graphics-card-for-400/#findComment-590241
