Hey guys,
I'm helping a friend troubleshoot an issue on his rig.  He's having weird audio latency issues.  It occurs on both his Xonar Essence STX and onboard audio although the problem only occurs after the machine has been on for awhile (which makes it a pain to troubleshoot).  Here's his setup:
Core i7 4770k
Gigabyte Z87X-UD3H
MSI GeForce GTX 780
Asus Xonar Essence STX
Corsair AX760i
Corsair Vengeance 1866Mhz
I thought it might be related to PCI-E configuration so I switched it off of auto to Gen2 so testing that now.  Any other ideas?
Current Rig
AMD Ryzen 5900X - Asus ROG Strix X570-E Gaming WiFi 2 - 32 GB GSkill TridentZ RGB
GeForce RTX 3080 - WD Black SN850 1TB  - Lian Li O11 Dynamic XL
https://linustechtips.com/topic/44921-audio-latency-problem/
How old is the installation of Windows?
https://linustechtips.com/topic/44921-audio-latency-problem/#findComment-589783
 Maybe two months.  He just built this this summer.
Current Rig
https://linustechtips.com/topic/44921-audio-latency-problem/#findComment-590040
You could try installing the UNi Xonar Drivers and see if that solves the issues.
http://maxedtech.com/asus-xonar-unified-drivers/
CPU: i5 4690K  CPU Cooler: Corsair H100   Motherboard: Gigabyte Z97X UD3H   Memory: G.Skill (2 x 4GB) DDR3-1866   Storage: Samsung 830 Series 128GB 2.5" SSD/Seagate Barracuda 1TB 3.5" 7200RPM   GPU: EVGA GeForce GTX 660 Ti SC 2GB   Case: Cooler Master CM 690 II (Black) ATX Mid Tower   PSU: CORSAIR Enthusiast Series TX650M 650W 80 PLUS BRONZE Certified   Optical Drive: MSI DH-24AAS-17 R DVD/CD Writer   Operating System: Windows 10 Pro (64 bit)
https://linustechtips.com/topic/44921-audio-latency-problem/#findComment-590087
It's my build that Crion is helping with.
I actually installed the UNI drivers shortly after the problem first appeared, and I just double-checked and I'm still running the latest version. Sadly, they haven't helped.
Also, the PCI-E configuration that Crion had me try hasn't stopped it either.
https://linustechtips.com/topic/44921-audio-latency-problem/#findComment-610103
Have you tried your front panel audio jack? Does it still do it?
https://linustechtips.com/topic/44921-audio-latency-problem/#findComment-611444
Welcome to the forums, lxndrdagreat.  It should hopefully be easier with people directly giving you suggestions.
Current Rig
https://linustechtips.com/topic/44921-audio-latency-problem/#findComment-612585
Maybe this threat will help you out? I haven't read through the whole thing, but it seems it might have some useful information. Seems this isn't an uncommon issue with that card.
http://www.head-fi.org/t/585158/asus-xonar-essence-stx-bugs-problems
https://linustechtips.com/topic/44921-audio-latency-problem/#findComment-628062
I've thought of something else...have you made sure your BIOS is up to date?
Yeah, I've been regularly checking and keeping that up to date.
On a random whim, I tried putting the computer to sleep next time the problem showed up (instead of rebooting). I waited a few minutes and woke the machine back up. Running a latency checker and then playing music, everything looks fine again.
https://linustechtips.com/topic/44921-audio-latency-problem/#findComment-631336
After a clean boot,  there isn't a problem with the sound. After a while of uptime (less than a day for sure, usually somewhere around eight hours), there will start to be an extremely noticeable problem with the sound. When playing music, it will sound like it has buffering problems, as well as playing at a slightly slower speed than normal. Looking at a latency checker (using DPC Latency Checker), the latency will be in the red, usually over 16000µs. This occurs whether I am using the STX or the onboard audio (I tried removing the STX card altogether for a week with the same results).
I will also get a very slight but noticeable stutter with the video at regular intervals (I mostly notice this in-game, but the mouse pointer will stutter going across the desktop as well).
As soon as I reboot, the problem disappears for a few hours.
I've updated the BIOS, tried rolling back to the drivers that came with my GTX 780, tried the most recent Nvidia drivers, tried the beta Nvidia drivers, disabled all audio drivers in device manager and tried only one at a time.
None of these have worked.
I have also run Prime95 and done a Memtest, neither of which found any issues.
https://linustechtips.com/topic/44921-audio-latency-problem/#findComment-631731
You may have to contact Gigabyte.  I hate to say it but at this point it's looking to be a mobo issue.
Current Rig
https://linustechtips.com/topic/44921-audio-latency-problem/#findComment-633518
