My Finished Build. Color Fails XD
DannyRyu
Hey guys this is my Build.
Here are the Specs and Some pictures.
CPU: Intel Core i3-4170 3.7GHz Dual-Core Processor  ($112.99 @ NCIX US)
Motherboard: Gigabyte GA-Z97X-Gaming 3 ATX LGA1150 Motherboard  ($121.99 @ SuperBiiz)
Storage: Samsung 850 EVO-Series 250GB 2.5" Solid State Drive  ($89.89 @ OutletPC)
Video Card: MSI GeForce GTX 960 4GB Video Card  ($239.99 @ Amazon)
Case: Thermaltake Versa H25 ATX Mid Tower Case  ($47.99 @ SuperBiiz)
Total: $781.82
Generated by PCPartPicker 2015-09-13 06:43 EDT-0400
Going to be upgrading to an i5-4790K and an R9 390 in the near future
Sorry for low quality pictures despite it being in 4K, I think the camera might be up-scaling
Shitload of Pictures at stupid resolution might take up some bandwidth.
or Imgur Album (same pics)
tsif8Cj.jpgM7JhShF.jpgr6ImhpP.jpgJLQ71Ky.jpg3uKd6S6.jpgAeJRhSt.jpgNwAUZB4.jpgPPtjMic.jpgpTQgQwE.jpgTewglRR.jpgvRiLDXI.jpg
Opinions? How's My Cable management and yes I failed at peripheral colors xD
Also my Speaker system is
Logitech Speaker System Z532
and
I have a 32 inch 1080p 60hz TV as a monitor. its a brand called Asiaventerlink Normal people can't buy it. its only sold at US military installations in the pacific area.
their made of a pretty high quality apparently :D
If you're not into modding you should at least get some cable extensions even tho they're filling up the back of the case it would give you a much cleaner look :)
I personally would have gotten another CPU but that's just my opinion
Also get another cooler :)  :)
Yeah planning on the CPU cooler but with the extensions I can't because the clearance in the back side of the case is pretty slim, it barely fits so I can't really have cable extensions :( the other side of the side panel is bulging very slightly.
Btw Asiaventerlink is sold for all maritime vessels at least we do so where i work
but they are nice
yeah thats a problem then :/
but they are nice
Yeah I wish I could test out the Response time but I'm not exactly professional player so a couple of MS isn't bad I would assume xD
mostly the ones we sell have a 4ms response time :) i guess that is good for standard use
I'm assuming there are no cable management holes for the cpu 4 pin power cable.
Could you twist tie that cable to the vents in the top of the case rather than resting it on the memory?
Otherwise it's a pretty good build.  :)
Thanks :) Just checked but can't ziptie it to anything :(
