How to change UEFI Firmware splash screen for X-99 Deluxe
Solved by Matrix Leader,
I see your problem, you have to install ez update.
BTW, I figured out how to do it through AiSuite. Initially I wasn't seeing the MyLogo in EZ Update because I was launching EZ Update from the taskbar icon. When I launched it through Ai suite then I saw the option to launch MyLogo. Here is how to do it:
1
4
1
Gat Pelsinger ·
Posted in CPUs, Motherboards, and Memory7 -
2
frozensun ·
Posted in Power Supplies7 -
3
