Here is a video i took of the problem's
1. It takes FOREVER to load into the map
2. Once loaded, i fall from the sky
3. Chunks load super slow (it may look fastish in video, but i partly used 2x speed)
4. It takes forever when i click leave game or whatever, it freaks out, and sais crashes, and goes to the launcher and sais it ran 23,000+ms behind
https://www.youtube.com/watch?v=L1BtWKeFbHM
THAT MOMENT YOU DISASSEMBLE YOUR COMPUTER....AND REASSEMBLE IT ....JUST SO SENPAI WILL NOTICE YOU
https://linustechtips.com/topic/448284-minecraft-chunk-loading-problems/
my minecraft server does the same thing generating terrain. It doesnt matter how much ram you allocate (I have tested up to 32, I have a total of 64) and it doesnt seem to matter how powerful your CPU is (I have a 12 thread 3930k) it just doesnt seem to use its resources at all...
Your playing amplified which seems to be buggy naturally, plus it would take longer anyway due to more blocks loading so in combo it lag loads chunks and has more chunk errors
https://linustechtips.com/main/topic/631048-psu-tier-list-updated/ Tier Breakdown (My understanding)--1 Godly, 2 Great, 3 Good, 4 Average, 5 Meh, 6 Bad, 7 Awful
Also whats your java version that is IMPORTANT
Same question to you what's your java version, keep I mind I assume minecraft is updated fully
latest version from a couple days ago.
Java 8 64 bit latest update, then there is nothing you can do its just minecraft being derp
I'm just glad my version loads quickly even at 32 render distance but I also don't use amplified and had to change my java as I was using an outdated version that hated water lighting affects
I am running shaders :3
how do i check my java version? i try using the browser to check...but chrome dosn't like it lol
Yeah I have to just not with the 32 render distance that I keep at 16
F3
In game of course
oh ok, is this info good or bad? haha
You have the version I upgrade from so you may want to update it as it causes lag
Do you have a link? to where the new one is? cause im not that good at updating java
Grab the OFFLINE 64 bit version https://java.com/en/download/manual.jsp
This works
This works
So i tried it, the first second it loads chuck's super fast, then after that its the same ..as in the video....also....its not just in the amplified world...i have same problem in default world....i can fly faster than chunks load
Well then I can't help as it is beyond my minecraft debugging capabilities, it's really surprising though as your computer has the same ram allocation for minecraft, the same gpu (which minecraft doesn't really care about) the only difference is I have a 4790k and its not like your cpu is running at 100% load so its likely an optimization somewhere else, my OS is Windows 7 pro maybe that's different than you but realistically that shouldn't be a hold up regardless
