Hey guys, uh.... my previous file have been corrupted and that is where I kept my GTAV at. Can I get GTAV running again from getting it online from Rockstar, Because I got it as a Hard Copy not from Steam or something, Can I get it again? Or it's just....lost or something and I need to buy a new one?
https://linustechtips.com/topic/447908-need-help-regarding-gtav/
you said you got hard copy, just repair it , really, are you really asking if you should buy a new copy ?
post-21562-0-16716800-1441969209_thumb.j
AMD 5000 Series Ryzen 7 5800X| MSI MAG X570 Tomahawk WiFi | G.SKILL Trident Z RGB 32GB (2 * 16GB) DDR4 3200MHz CL16-18-18-38 | Asus GeForce GTX 3080Ti STRIX | SAMSUNG 980 PRO 500GB PCIe NVMe Gen4 SSD M.2 + Samsung 970 EVO Plus 1TB PCIe NVMe M.2 (2280) Gen3 | Cooler Master V850 Gold V2 Modular | Corsair iCUE H115i RGB Pro XT | Cooler Master Box MB511 | ASUS TUF Gaming VG259Q Gaming Monitor 144Hz, 1ms, IPS, G-Sync | Logitech G 304 Lightspeed | Logitech G213 Gaming Keyboard |
PCPartPicker
https://linustechtips.com/topic/447908-need-help-regarding-gtav/#findComment-6005509
repair it? How? @,@ that was my first time buying a game as a hard copy
All my games are hard copy,
just insert the dvd, and click the setup and it will ask you to uninstall or repair the file,
and if you have HARD COPY social club repairs the games on start anyway, i dont get how can you have a corrupted game, it literally checks game's integrity before launch.
Uninstall GTA5, insert GTA5 disk, ???, profit
NO
  1. Uninstall GTA5
  2. Insert GTA5 disk
  3. ???
  4. Profit
only an inexperienced does that. every game has a repair option, you dont have to uninstall games to fix it.
PCPartPicker
https://linustechtips.com/topic/447908-need-help-regarding-gtav/#findComment-6005528
load up the disk again again and in the stall menu it will have an option to repair gta 5
Rigs I've Built
The Striker i5 4590 @ 3.7 ||  MSI GTX 980 Armor X2 || Corsair RMX 750 || Team Elite Plus 8 GB || Define S || MSI Z97S SLI Krait
The Office PC i3 4160 @ 3.6 || Intel 4600 || EVGA 500B || G.Skill 8 GB || Cooler Master N200 || ASRock H97M Pro4
The Friend PC G3258 @ 4.3 || Sapphire R9 280X Tri-X || EVGA 600B || 8 GB Dell Ram || Cooler Master N200 || ASRock H97M- iTX/ac
The Mom Gaming PC A10-7890K @ 4.4 || iGPU + ASUS R7 250 ||  8 GB Klevv DDR3-2800 Mhz
https://linustechtips.com/topic/447908-need-help-regarding-gtav/#findComment-6005535
NO
But My Hard Disk is corrupted and I tried to copy World of Warships which is in the old HDD as well and I copied it to the new HDD and when I tried to open it through there it says that it is corrupted bla...bla..bla.....
now, is it still able to do that on the corrupted hard disk? and then move it to the new HDD afterwards?
https://linustechtips.com/topic/447908-need-help-regarding-gtav/#findComment-6005560
Insert your DVD !!
PCPartPicker
https://linustechtips.com/topic/447908-need-help-regarding-gtav/#findComment-6005566
then......?
then this
it will open the setup, select repair. if it doesnt auto run on insert, open the dvd and run the setup.
PCPartPicker
https://linustechtips.com/topic/447908-need-help-regarding-gtav/#findComment-6005579
the seventh disk right? which is the last disk... right?
First disk, i Repeat, First Disk, the setup file is always on the first disk. do you use 7th disk at first to install GTA 5? no!!!
PCPartPicker
https://linustechtips.com/topic/447908-need-help-regarding-gtav/#findComment-6005590
but... it shows me the "things" to install it instead of like what you show me~
press install, it will open up repair if you have your game installed before. just show me a screen cap of what's happening.
PCPartPicker
https://linustechtips.com/topic/447908-need-help-regarding-gtav/#findComment-6005656
LOL, OP has had a NEW HDD with no existing files.
OP just install the game again then sign into your RGSC account when prompted and you'll be good to go.
Main Rig:-
Server:-
https://linustechtips.com/topic/447908-need-help-regarding-gtav/#findComment-6005698
i'm pulling hairs, i thought i was bad at wordings, the OP is all over the place.
PCPartPicker
https://linustechtips.com/topic/447908-need-help-regarding-gtav/#findComment-6005721
Just install the damn game all over from the DVD
PCPartPicker
https://linustechtips.com/topic/447908-need-help-regarding-gtav/#findComment-6005725
but what about the code? @,@ I though you can't use it again~
well you know... It would be much easier if this discussion was in my native language from the start~
https://linustechtips.com/topic/447908-need-help-regarding-gtav/#findComment-6006127
pretty sure it wont , as you just need to login again. if it asks just enter the code from the DVD again, dont worry it wont ask a new code. and its all cool. english is not my native either.
PCPartPicker
https://linustechtips.com/topic/447908-need-help-regarding-gtav/#findComment-6006357
