first off: use germany pcpartpicker.
second off: stuff is a tad more expensive in NL, so leave about €50 headroom in the budget.
EDIT: http://de.pcpartpicker.com/p/4KBw23 this is why you need the german PCPP
https://linustechtips.com/topic/447509-build-for-a-friend/#findComment-6000079
http://de.pcpartpicker.com/p/nf93pg
this is a pretty beefy build
Main PC |CPU - i7-6700k|GPU - R9 290x tri-x 4gb|RAM - 16gb ddr4|MOBO - MSI z170 - A PRO|HDD - WD 1TB/240gb Sandisk |PSU - 700w Raidmax
Laptop |CPU - i7 4720hq|GPU - 960m 2gb|Ram - 8gb 2x4|Model - y50-70 Touch|SSD - 240gb Patriot drive|Display - 1920x1080 IPS touch
https://linustechtips.com/topic/447509-build-for-a-friend/#findComment-6000103
you missed my comment on price differences.
but yes, looking good.
but i used the german pc part picker
https://linustechtips.com/topic/447509-build-for-a-friend/#findComment-6000138
stuff is generally a bit cheaper in germany than in the netherlands,
so in the end its a *tiny bit* over budget.
ah i see. not getting this though would be a shame.
https://linustechtips.com/topic/447509-build-for-a-friend/#findComment-6000172
