Is it possible to copy the work folder so my work and progress is still there after a reinstall?
CPU: Intel Core i7 4790K
CPU Cooler: Noctua NH-D15
RAM: Corsair Vengeance Pro 16GB 1866MHz
GPU: Asus Strix RTX 2060 OC
Motherboard: Asus Maximus VII Hero
Storage: 1TB, 500GB, 250GB SSD's, 1TB SSHD
Case: Corsair Carbide Air 540
https://linustechtips.com/topic/447328-move-fah-work/
FAH???
And yes it should be possible.
CPU: Intel I7 4790K 4.8 Ghz || Mobo: ASUS ROG Maximus Hero 6 Z87 || Ram: Corsair Vengeance 16 GB 1600 Mhz || GPU: ASUS GTX 980 Ti STRIX || Storage: 2 x SSD Samsung 840 EVO 250 GB RAID 0 HDD Western Digital 1 TB Black || PSU: Corsair AX 860 watt || Cooling: 2 x AF 140mm (front), 2 AF120 Blue LED (bottom and back), 2 SP120 (top on radiator) ||  CPU cooler: Corsair H100i GTX || Case: Corsair obsidian 750D <3 <3 <3
https://linustechtips.com/topic/447328-move-fah-work/#findComment-5997001
FAH???
Folding@Home
https://linustechtips.com/topic/447328-move-fah-work/#findComment-5997008
if you remove F@H it will give you a message do you want to remove data yes or no! just press No and the WU's will just stay there after reinstall or new install
EOC folding stats - Folding stats - My web folding page stats
Summer Glau: Quote's The future is worth fighting for. Serenity
My linux setup: CPU: I7 2600K @4.5Ghz, MM: Corsair 16GB vengeance @1600Mhz, GPU: 2 Way Radeon his iceq x2 7970, MB: Asus sabertooth Z77, PSU: Corsair 750 plus Gold modular
My gaming setup: CPU: I7 3770K @4.7Ghz, MM: Corsair 32GB vengeance @1600Mhz, GPU: 2 Way Gigabyte RX580 8GB, MB: Asus sabertooth Z77, PSU: Corsair 860i Platinum modular
https://linustechtips.com/topic/447328-move-fah-work/#findComment-6000812
I was reinstalling Win 7 so i was worried the OS change would mess the WU's up. It did work but the log gave me some errors so i dumped the WU's just to be sure. Back to folding!
https://linustechtips.com/topic/447328-move-fah-work/#findComment-6007511
Reinstalling your OS would kill it, just reinstalling the program itself won't if you don't check that option.
Forum Links - Community Standards, Privacy Policy, FAQ, Features Suggestions, Bug and Issues.
Folding/Boinc Info - Check out the Folding and Boinc Section, read the Folding Install thread and the Folding FAQ. Info on Boinc is here. Don't forget to join team 223518. Check out other users Folding Rigs for ideas. Don't forget to follow the @LTTCompute for updates and other random posts about the various teams.
Follow me on Twitter for updates @Whaler_99
https://linustechtips.com/topic/447328-move-fah-work/#findComment-6014676
I copied all the FAH files but it was unstable so i dumped the work and reinstall F@H just to be sure.
https://linustechtips.com/topic/447328-move-fah-work/#findComment-6014953
