CPU: Intel Core i5-4690K 3.5GHz Quad-Core Processor ($229.99 @ NCIX US)
CPU Cooler: Corsair H80i GT 70.7 CFM Liquid CPU Cooler ($89.24 @ Amazon)
Motherboard: MSI Z97S SLI Krait Edition ATX LGA1150 Motherboard ($115.99 @ SuperBiiz)
Memory: G.Skill Ripjaws X Series 8GB (2 x 4GB) DDR3-1600 Memory ($45.89 @ OutletPC)
Storage: Samsung 850 EVO-Series 250GB 2.5" Solid State Drive ($97.56 @ OutletPC)
Storage: Western Digital Caviar Blue 1TB 3.5" 7200RPM Internal Hard Drive ($50.89 @ OutletPC)
Video Card: MSI Radeon R9 390 8GB Video Card ($329.98 @ SuperBiiz)
Case: NZXT S340 (Black) ATX Mid Tower Case ($68.99 @ SuperBiiz)
Power Supply: EVGA 750W 80+ Gold Certified Fully-Modular ATX Power Supply ($99.99 @ Newegg)
Total: $1128.52
Generated by PCPartPicker 2015-09-09 20:21 EDT-0400
https://linustechtips.com/topic/447184-first-build/#findComment-5994996
I have to question the point of an expensive cooling solution for a not-very-expensive CPU.  I see a lot of people saying to use AIO coolers for i5s but surely that money would be better spent buying an i7 instead?
Either way, to OP:  mATX allows smaller builds but it COULD be more expensive in some cases by a little.  Not much though, depends what's important to you.  With a single GPU it makes no difference pretty much.
edit - @utah960 that's a terrible graphics card for a build of the price range.  But it looks like a joke anyway so nevermind ;)
https://linustechtips.com/topic/447184-first-build/#findComment-5995036
little bit over btu im sure you can find a cheaper variant or diferent company and bring down the price
http://pcpartpicker.com/p/G6gVK8
The Ninja (current gaming pc)  Case- h440 red/black cpu- i5-4690k@ 4.3ghz cooler- coolermaster hyper 212 evo moboGigabyte z97x-sli ram- adata xpg v.1 2x4gb 1600mhz gpu- asus strix gtx 970 hdd- wd blue 1tb ssd- kingston hyperx savage 240gb psu- evga 600b peripherals: mouse- razer death adder 2013 keyboard- corsair k70 with chery mx-reds headset- HyperX Cloud 2
my laptop- toshiba satelite p850, cpu- i7-3630qm ram- 8gb 1600mhz hdd- 1tb 5400rpm gpu- Nvidia gt630m 2gb
did you know we have a gun thread ? well we do
and a car thread !
https://linustechtips.com/topic/447184-first-build/#findComment-5995084
heres a white and black build its 2 dollars over budget but it uses skylake cpu http://pcpartpicker.com/p/P7F73C
Project Iridium:   CPU: Intel 4820K   CPU Cooler: Custom Loop  Motherboard: Asus Rampage IV Black Edition   RAM: Avexir Blitz  Storage: Samsung 840 EVO 250GB SSD and Seagate Barracuda 3TB HDD   GPU: Asus 780 6GB Strix   Case: IN WIN 909   PSU: Corsair RM1000      Project Iridium build log http://linustechtips.com/main/topic/451088-project-iridium-build-log/
https://linustechtips.com/topic/447184-first-build/#findComment-5995085
Hi, i'm planning to get a new pc. As this is my first build, i really don't have any experience with pc building and choosing the right parts.
I don't know if i go micro atx or atx.
My budget is around 1100 dollars.
Can someone help me...
Thanks
my build also includes windows 10 http://pcpartpicker.com/p/G6gVK8
and a car thread !
https://linustechtips.com/topic/447184-first-build/#findComment-5995094
why do peoplpe choose the h80i its a terrible deal you can get a 240mm aio for 10$ less....
and a car thread !
https://linustechtips.com/topic/447184-first-build/#findComment-5995099
but if over time you want to start overclocking your rig it helps a lot and also if your gonna use this as a work station get a different mobo and like an AMD FX 9590 with is an 8 core monster wit a stock speed of 4.7 ghz  the yes a liquid cooler is needed or at least helpful but mandatory for the 9590  there is one that amd makes that comes with a liquid cooler
https://linustechtips.com/topic/447184-first-build/#findComment-5995101
corsairs a reliable company i have never had any problems with my h100i
https://linustechtips.com/topic/447184-first-build/#findComment-5995102
i get the reliability but it still wont perform as good as any 240mm cooler, its one of the most expensive 120mm aios and its even more expensive then some 240mm and thats when i question its price especially since its outdated  and has been replaced by the h80igt and the new generation
and a car thread !
https://linustechtips.com/topic/447184-first-build/#findComment-5995128
if hes going for workstation he should go i7 with a cheaper air cooler then a 9590 and a aio
and a car thread !
https://linustechtips.com/topic/447184-first-build/#findComment-5995135
it is the h80igt that i choose
https://linustechtips.com/topic/447184-first-build/#findComment-5995152
hmm for some reason i only  seen h80i, either way its a expensive cpu cooler for what it is
and a car thread !
https://linustechtips.com/topic/447184-first-build/#findComment-5995244
No-one in their right mind would buy an FX-9590 cpu.
https://linustechtips.com/topic/447184-first-build/#findComment-5995254
:) finally somebody agrees with me
and a car thread !
https://linustechtips.com/topic/447184-first-build/#findComment-5995424
