Here are the parts that I have found to make up what I think is a good computer for gaming and streaming through twitch and all of that fun stuff.
Fractal Design Define R4 Black Pearl Case http://www.newegg.com/Product/Product.aspx?Item=N82E16811352020
Crucial 2.5" 500 GB SATA 6Gbps SSD http://www.newegg.com/Product/Product.aspx?Item=N82E16820148946
EVGA GeForce GTX 960 http://www.newegg.com/Product/Product.aspx?Item=N82E16814487091
GSkill Ripjaw Series 8GB 2x4GB http://www.newegg.com/Product/Product.aspx?Item=N82E16820231314
Intel Core i7-4790k http://www.newegg.com/Product/Product.aspx?Item=N82E16819117369&cm_re=4790k-_-19-117-369-_-Product
Asus H97-PRO GAMER http://www.newegg.com/Product/Product.aspx?Item=N82E16813132415
Corsair CX Series CX430M 430W http://www.newegg.com/Product/Product.aspx?Item=N82E16817139049
maybe optional/optional/necessary/idk:
Cooler Master Hyper Evo 212 http://www.newegg.com/Product/Product.aspx?Item=N82E16835103099
What do you guys think?
edit:
So here's my new parts list so far:
CPU: Intel Xeon E3-1231 V3 3.4GHz Quad-Core Processor  ($242.99 @ SuperBiiz)
CPU Cooler: Cooler Master Hyper 212 EVO 82.9 CFM Sleeve Bearing CPU Cooler  ($24.99 @ Newegg)
Motherboard: Gigabyte GA-H97M-HD3 Micro ATX LGA1150 Motherboard  ($76.98 @ Newegg)
Memory: Kingston HyperX Fury Black 8GB (2 x 4GB) DDR3-1333 Memory  ($42.49 @ SuperBiiz)
Storage: Samsung 850 EVO-Series 120GB 2.5" Solid State Drive  ($70.49 @ OutletPC)
Storage: Western Digital Caviar Blue 1TB 3.5" 7200RPM Internal Hard Drive  ($50.89 @ OutletPC)
Video Card: MSI Radeon R9 390 8GB Video Card  ($329.98 @ SuperBiiz)
Case: Fractal Design Core 2500 ATX Mid Tower Case  ($46.99 @ Directron)
Power Supply: SeaSonic S12G 650W 80+ Gold Certified ATX Power Supply  ($95.98 @ Newegg)
(don_svetlio's build suggestion)
https://linustechtips.com/topic/447167-building-my-first-pc/
Bad idea? Budget and location?
https://linustechtips.com/topic/447167-building-my-first-pc/#findComment-5994679
Get a Xeon1231v3 w/ a H97 motherboard, and a R9 390.
Then don't get that PSU. It's not good for high end systems, it has a low max temperature that'll result.. Well in a faulty power supply.
Get a EVGA g2 or GS
Any XFX
Any SeaSonic
Or any SuperFlower.
i7-6700k  Cooling: Deepcool Captain 240EX White GPU: GTX 1080Ti EVGA FTW3 Mobo: AsRock Z170 Extreme4 Case: Phanteks P400s TG Special Black/White PSU: EVGA 850w GQ Ram: 64GB (3200Mhz 16x4 Corsair Vengeance RGB) Storage 1x 1TB Seagate Barracuda 240GBSandisk SSDPlus, 480GB OCZ Trion 150, 1TB Crucial NVMe
(Rest of Specs on Profile)
https://linustechtips.com/topic/447167-building-my-first-pc/#findComment-5994683
http://linustechtips.com/main/topic/406160-psu-ranking-and-tiers/
refer to this chart for power supply choice.
either get a non-k cpu (or xeon) with a H97 board
or get a k cpu with a Z97 board
certainly when going overclockable i7, you *want* that cooler.
cut back on the SSD a bit, 500GB is a tad overkill.
add an extra hard drive instead, so you have a decent chunk of storage.
get a define R5 over that define R4, its a bit more "refined"
https://linustechtips.com/topic/447167-building-my-first-pc/#findComment-5994716
CPU: Intel Core i5-4690K 3.5GHz Quad-Core Processor  ($229.99 @ NCIX US)
Motherboard: ASRock Z97M Pro4 Micro ATX LGA1150 Motherboard  ($77.98 @ Newegg)
Video Card: Sapphire Radeon R9 380 4GB Nitro Video Card  ($213.98 @ Newegg)
Total: $853.78
Generated by PCPartPicker 2015-09-09 19:49 EDT-0400
https://linustechtips.com/topic/447167-building-my-first-pc/#findComment-5994722
I heard of the forums from this video:
and wanted opinions/suggestions.
 best resource i can recommend is pcpartpicker because it shows you incompatibilitys for example im pretty sure devils canyon cpus dont come with a cooler so you would need to buy an aftermarket cooler
Project Iridium:   CPU: Intel 4820K   CPU Cooler: Custom Loop  Motherboard: Asus Rampage IV Black Edition   RAM: Avexir Blitz  Storage: Samsung 840 EVO 250GB SSD and Seagate Barracuda 3TB HDD   GPU: Asus 780 6GB Strix   Case: IN WIN 909   PSU: Corsair RM1000      Project Iridium build log http://linustechtips.com/main/topic/451088-project-iridium-build-log/
https://linustechtips.com/topic/447167-building-my-first-pc/#findComment-5994725
Much better.
https://linustechtips.com/topic/447167-building-my-first-pc/#findComment-5994726
they do - the crappy intel stock cooler they've been shipping since pentium 3
https://linustechtips.com/topic/447167-building-my-first-pc/#findComment-5994728
huh didn't know that
https://linustechtips.com/topic/447167-building-my-first-pc/#findComment-5994732
PCPartPicker part list / Price breakdown by merchantCPU: Intel Core i5-4690K 3.5GHz Quad-Core Processor  ($229.99 @ NCIX US)CPU Cooler: Cooler Master Hyper 212 EVO 82.9 CFM Sleeve Bearing CPU Cooler  ($24.99 @ Newegg)Motherboard: ASRock Z97M Pro4 Micro ATX LGA1150 Motherboard  ($77.98 @ Newegg)Memory: Kingston HyperX Fury Black 8GB (2 x 4GB) DDR3-1333 Memory  ($42.49 @ SuperBiiz)Storage: Samsung 850 EVO-Series 120GB 2.5" Solid State Drive  ($70.49 @ OutletPC)Storage: Western Digital Caviar Blue 1TB 3.5" 7200RPM Internal Hard Drive  ($50.89 @ OutletPC)Video Card: Sapphire Radeon R9 380 4GB Nitro Video Card  ($213.98 @ Newegg)Case: Fractal Design Core 2500 ATX Mid Tower Case  ($46.99 @ Directron)Power Supply: SeaSonic S12G 650W 80+ Gold Certified ATX Power Supply  ($95.98 @ Newegg)Total: $853.78Prices include shipping, taxes, and discounts when availableGenerated by PCPartPicker 2015-09-09 19:49 EDT-0400
The the extra $20 for a 250gb SSD. Also get a BeQuiet! Pure Rock CPU. He mentioned streaming and stuff, get a Xeon 1231v3 w/ H97 motherboard and the Pure Rock for a more quiet build.
https://linustechtips.com/topic/447167-building-my-first-pc/#findComment-5994739
well - my 4590 reached temps such as 67*C with it so I scrapped it. 48*C max now :D
https://linustechtips.com/topic/447167-building-my-first-pc/#findComment-5994740
4690K is enough for streaming @1080p 60 fps as long as his  internet is okay. No worries on that.
https://linustechtips.com/topic/447167-building-my-first-pc/#findComment-5994745
What you have laid out there, Sir, is not a gaming computer.  The CPU is far to powerful compared to the graphics card for gaming to the point where you are wasting money.
Also get a 120 GB SSD and a 1 TB hard drive (WD blue, for example).
Also don't get that PSU.. it's a total piece of junk.  Take a Seasonic G2 520 watt instead,  a bit more expensive but far higher quality.
https://linustechtips.com/topic/447167-building-my-first-pc/#findComment-5994751
Xeon will be a LOT better
https://linustechtips.com/topic/447167-building-my-first-pc/#findComment-5994753
S12G is cheaper :D
https://linustechtips.com/topic/447167-building-my-first-pc/#findComment-5994757
4690K is sexier :P
https://linustechtips.com/topic/447167-building-my-first-pc/#findComment-5994758
Obligatory Xeon version
Total: $865.78
Generated by PCPartPicker 2015-09-09 19:55 EDT-0400
https://linustechtips.com/topic/447167-building-my-first-pc/#findComment-5994767
you're actually wrong, they got smaller over time...
he mentioned he's gonna be streaming, you need a decent chunk of cpu power to get your stream compressed right.
https://linustechtips.com/topic/447167-building-my-first-pc/#findComment-5994770
Nothing an i5 can't handle really.
https://linustechtips.com/topic/447167-building-my-first-pc/#findComment-5994777
Well there are plenty of options of course.  People who don't know what units are high quality read this please ;)
http://www.tomshardware.co.uk/forum/id-2547993/psu-tier-list.html
Shit - no, no no no. That's old and crap. It lists Delta as "bad", Fuck no.
http://linustechtips.com/main/topic/406160-psu-ranking-and-tiers/ - THIS!
https://linustechtips.com/topic/447167-building-my-first-pc/#findComment-5994783
Total: $865.78
Pretty good, but at this price point you could might as well bump it to at least r9 390. :)
Depends on his budget, not picking on you :P
My modded Air 540 build
https://linustechtips.com/topic/447167-building-my-first-pc/#findComment-5994785
A few questions first. What's your budget? Do you plan on overclocking? What kind of games do you plan and what settings do you hope to play them at? As for what you have now, it all looks good in general. However, I suggest getting a lower capacity ssd and a mechanical hard drive. I've always liked that combo. Many people here will say the r9 380 is a better choice for the gpu, but 960 is good as well, but you should get the 4 GB model. Finally, consider a PSU upgrade. The CX is ok, but it's as basic as you can get. Also, have you used pcpartpicker to choose your parts? It's really helpful
https://linustechtips.com/topic/447167-building-my-first-pc/#findComment-5994786
