I have a fan for my window, can it damage the fan to have a restrictive filter on it?
https://linustechtips.com/topic/447041-safe-to-filter-fan/
Unless the fan is physically touching the filter (like rubbing it which would be really loud anyways) then it won't have any impact other than a loss of airflow (which is a given)
CPU: INTEL Core i7 4790k @ 4.7Ghz - Cooling: NZXT Kraken X61 - Mobo: Gigabyte Z97X SLI - RAM: 16GB G.Skill Ares 2400mhz - GPU: AMD Sapphire Nitro R9 Fury 4G - Case: Phanteks P350X - PSU: EVGA 750GQ - Storage: WD Black 1TB - Fans: 2x Noctua NF-P14s (Push) / 2x Corsair AF140 (Pull) / 3x Corsair AF120 (Exhaust) - Keyboard: Corsair K70 Cherry MX Red - Mouse: Razer Deathadder Chroma
Bit of an AMD fan I suppose. I don't bias my replies to anything however, I just prefer AMD and their products. Buy whatever the H*CK you want.
---QUOTE ME OR I WILL LIKELY NOT REPLY---
https://linustechtips.com/topic/447041-safe-to-filter-fan/#findComment-5992680
like a box fan in your bedroom window?
Yeah
https://linustechtips.com/topic/447041-safe-to-filter-fan/#findComment-5992681
