So this is largely a repost of a post I made on reddit, but that didn't get much traction and I'm still feeling sorta lost.
I've got most of my build planned out, and I feel like the only thing I need to do is pick a case. Since I'm trying to make an on-top-of-desk build rather than a below-desk build, aesthetics are kinda important to me. I'm going to be going with an internal color scheme of either white/black or white/red, and haven't decided on that yet either. The only difference would basically be RAM and GPU choice: Black RAM and a Sapphire 390 for white/black vs red RAM and an MSI 390 (repainting the backplate white) in the red/white build. I will be using some form of AIO liquid cooling for this build, I haven't figured out what particular unit yet, in part because I haven't picked a case.
The issue is that I've got like five different cases that are all really attractive to me for various reasons, and I can't really decide well between them, so I'm soliciting input.
NZXT H440: Things I like: Chamber separation and hidden HDD cages, some noise-dampening foam, bunch of reasonable-quality fans already included, nice aesthetic. Things I don't like: Not the best airflow, especially from the front, is kinda big
Corsair Air 540 : Things I like: Chamber separation, airflow, nice big window, desk-friendly form factor (short and wide vs tall and skinny). Things I don't like: more expensive than other cases on this list, no noise dampening
Fractal Design Define R5 : Things I like: Brand reputation, build quality, lots of cable space behind MOBO tray, external aesthetics, most quiet case on the list. Things I don't like: no chamber separation, exposed HDD trays, few included fans
NZXT S340: Things I like: Smallest case on the list, cheapest case on the list. Things I don't like: Seems like front airflow might be a problem, seems like it'd require a 240mm or 280mm radiator for use in front, which might eat up some of the cost savings compared to other cases.
Phanteks Enthoo Pro : Things I like: well reviewed, has chamber separation, good bunch of included fans, dual-window aesthetic. Things I don't like: Relatively large, includes some unnecessary features (5.25" bays)
Any thoughts from people who've used these cases would be helpful, or who can recommend a case I haven't looked at yet (I am looking for something that is A: white and B:has a side window). I don't think any of them is a bad choice, I just want to make the best choice out of these.
https://linustechtips.com/topic/446446-help-choosing-a-case/
Phanteks Enthoo Luxe or have you looked at the NZXT Noctis 450?
i7-6700k  Cooling: Deepcool Captain 240EX White GPU: GTX 1080Ti EVGA FTW3 Mobo: AsRock Z170 Extreme4 Case: Phanteks P400s TG Special Black/White PSU: EVGA 850w GQ Ram: 64GB (3200Mhz 16x4 Corsair Vengeance RGB) Storage 1x 1TB Seagate Barracuda 240GBSandisk SSDPlus, 480GB OCZ Trion 150, 1TB Crucial NVMe
(Rest of Specs on Profile)
https://linustechtips.com/topic/446446-help-choosing-a-case/#findComment-5984005
The S340 shouldn't have any issues with airflow. There are two large openings at the top and bottom behind the front panel.
https://linustechtips.com/topic/446446-help-choosing-a-case/#findComment-5987892
The 450's aesthetics looks like it's trying a bit too hard.
I don't get it, do you prefer designers that don't try? The Noctis 450 is literally the H440 without the sound dampening qualities (which means good airflow).
CPU: Ryzen 5 3600X            | Cooler: Deepcool AK400  | Motherboard: B550 Elite AX V2  | Storage: Samsung 980 Pro 1TB  |
RAM: Corsair Vengeance 16GB   | GPU: MSI RTX 3060 Ti    | Case: NZXT H440 (Red/Black)    | PSU: EVGA 650W G2             |
https://linustechtips.com/topic/446446-help-choosing-a-case/#findComment-5987997
If I end up using the S340, would you recommend a 240/280mm AIO on the front or a 120/140mm AIO with another non-rad case fan in the front?
https://linustechtips.com/topic/446446-help-choosing-a-case/#findComment-5988037
Depending on what you're cooling, either is fine.
https://linustechtips.com/topic/446446-help-choosing-a-case/#findComment-5988043
The front and top panels are too angular and overdesigned for my tastes.
Fair enough.
https://linustechtips.com/topic/446446-help-choosing-a-case/#findComment-5988046
I liked the S340 compared to the H440. Unless you liked cubed casing, Air 540 is a-ok.
ROG X570-F Strix AMD R9 5900X | EK Elite 360 | EVGA 3080 FTW3 Ultra | G.Skill Trident Z Neo 64gb | Samsung 980 PRO
ROG Strix XG349C Corsair 4000 | Bose C5 | ROG Swift PG279Q
Logitech G810 Orion Sennheiser HD 518 |  Logitech 502 Hero
https://linustechtips.com/topic/446446-help-choosing-a-case/#findComment-5988146
what about coolermaster's mastercase pro 5?
It's all black though, and quite expensive too ($140), but it's really customizable
Edit : NZXT's phantom 410 seems nice, lots of color scheme and look unique too (except for its side panel, not in the way you like it i guess), consider the 240 too, but the 240 comes in only black and white
https://linustechtips.com/topic/446446-help-choosing-a-case/#findComment-5988295
