Hey Guys!
I'm a super noob at Modding, as in I've never done any modding before.... kind of in the middle of a Bluray Stealth Mod but that's it.
I'm wanting to paint my GTX 980's for my black and white build but not sure at all how to go about it. Got any sweet tips? Any and all advice, suggestions, recommendations are very much appreciated. Thanks!
Kill the Machine!
https://linustechtips.com/topic/445398-paint-gtx-980-reference/
Hey Guys!
This video basically shows what you want to do, Just use your own colours.
https://linustechtips.com/topic/445398-paint-gtx-980-reference/#findComment-5968556
If you use plasti-dip, which I would recommend, you will need washers for putting the 8 larger screws back on without tearing away the plasti-dip.
I painted my own GTX 780 Ti reference cards so... If you have any specific questions you can send me a PM.
https://linustechtips.com/topic/445398-paint-gtx-980-reference/#findComment-5968587
O
Only thing, this guy has the worst spraying technique ever!!!
LTT's Fastest single core CineBench 11.5/15 score on air with i7-4790K on air
Main Rig
CPU: i7-4770K @ 4.3GHz 1.18v, Cooler: Noctua NH-U14S, Motherboard: Asus Sabertooth Mark 2, RAM: 16 GB G.Skill Sniper Series @ 1866MHz, GPU: EVGA 980Ti Classified @ 1507/1977MHz , Storage: 500GB 850 EVO, WD Cavier Black/Blue 1TB+1TB,  Power Supply: Corsair HX 750W, Case: Fractal Design r4 Black Pearl w/ Window, OS: Windows 10 Home 64bit
Plex Server WIP
CPU: i5-3570K, Cooler: Stock, Motherboard: ASrock, Ram: 16GB, GPU: Intel igpu, Storage: 120GB Kingston SSD, 6TB WD Red, Powersupply: Corsair TX 750W, Case: Corsair Carbide Spec-01 OS: Windows 10
Lenovo Legion Laptop
CPU: i7-7700HQ, RAM: 8GB, GPU: 1050Ti 4GB, Storage: 500GB Crucial MX500, OS: Windows 10
https://linustechtips.com/topic/445398-paint-gtx-980-reference/#findComment-5968663
Hey Guys!
here I have a guide or writeup that covers GPU Painting and General Painting techniques for different materials, and it also references that video already posted:
http://linustechtips.com/main/topic/407754-modding-faq-common-mods/
https://linustechtips.com/topic/445398-paint-gtx-980-reference/#findComment-5968780
Is plasti dip a type of paint or a mod technique?
Kill the Machine!
https://linustechtips.com/topic/445398-paint-gtx-980-reference/#findComment-5977913
Plasti-dip is a rubber based spray paint product it makes it possible for you to peel off the coating if you decide to change color or revert back to original.
https://linustechtips.com/topic/445398-paint-gtx-980-reference/#findComment-5977934
It's a rubberized coating, you can get it commonly in aerosol form and use it just like spray paint. Unlike paint, plasti-dip can be easily peeled off if you make a mistake or want to remove it, and it will look like it was never there.
http://www.amazon.com/Performix-11203-Multi-Purpose-Coating-Aerosol/dp/B0006SU3QW/ref=sr_1_1?ie=UTF8&qid=1441673962&sr=8-1&keywords=plasti-dip
https://linustechtips.com/topic/445398-paint-gtx-980-reference/#findComment-5978325
Don't cheap out on they paint, either use automotive grade spay paint or plasidip.
Plasitdip is cheap as hell looking. If you going to paint it use actual paint.
MainRig- CPU: 4790k, RAM: 32gb 2400mhz, MOBO: Maximus Formula VII, COOLING: Full EK cooling, GPU: Titan X SLI, PSU: 1200w evga , STORAGE: 250gb SSD, 4TB hybrid CASE: 760T, EXTRAS: Sleeved cables
SecondRig- CPU:4690K, RAM: 16gb 1600mhz, MOBO: Maximus Gene VII, COOLING: H105, GPU: 970ftw, PSU: EVG650W,  STORAGE: 250gb SSD, 3TB, CASE: 540air
Steam: pizzatime6 Plus two other pc rigs and a craptop.
https://linustechtips.com/topic/445398-paint-gtx-980-reference/#findComment-5978387
