I GET FPS DROPS IN EVERY GAME! (please please please help me)
lovingGamer
OKAY FIRST I THOUGHT IT WAS ONLY IN BF4 BUT WHEN I STARTED GTA V TO PLAY FPS DROPPED TO 4 FPS!
I IMMEDIATELY WENT TO BF3 AND I NOTICE LITTLE FPS DROPS... NOT MUCH BUT STILL IT'S AN FPS DROP!
Is my GPU dying or CPU? or RAM?! WTF! I need help! please!
EDIT: I HAVE latest drivers!!!
EDIT specs: I3 4150 R9 280X 8 GB of RAM
the MSI 280X had issues with overheating memory - might be something of the sorts. Also VRMs on launch would overheat. Check your GPU's bios.
STOP USING CAPS IF YOU WANT TO GET A DECENT ANSWER AND FYI THATS NORMAL.
Not really - unless he's running out of VRAM I wouldn't call stuttering normal.
and running out of vram is not normal because?
This guy always has problems, perhaps it's you doing something? like so many apps open in the background that your i3 can't handle it all?
REDLINECore i7 6700k 4.8ghz 1.37v.Noctua NH-u12s.MSI Z170A Gaming M7.16GB Kingston Hyper X Fury Black.MSI Gaming R9 390 8GB Crossfire + GTX 780 PhysX.Samsung EVO 850 500GB SSD.Fractal Design Define R5 Midi Black.SeaSonic X Series 1050w Gold.Logitech G302 Deadalus Prime.Ducky DK2108 Zero Mech Cherry Blue.
GTA V displays VRAM usage - unless he's dumb enough to go past the limit I wouldn't say it's normal.
maybe is the CPU? an i3 isnt much, but the 280x should hold up
i9 11900k - NH-D15S - ASUS Z-590-F - 64GB 2400Mhz - 1080ti SC - 970evo 1TB - 960evo 250GB - 850evo 250GB - WDblack 1TB - WDblue 3TB - HX850i - 27GN850-B - PB278Q - VX229 - HP P224 - HP P224 - HannsG HT231 - 450D
displayed vram usage is not the real world case, I find that gta5 uses more than it tells me, which is quite normal as its not the only thing running on graphics card.
Get Display Driver Uninstaller. Completely uninstall your GPU drivers, and reinstall the new ones
I go past the limit all the time, no stutters or drops here.
NO background apps!! Everything is closed! bro
Witch Craft....
What settings are the games at? Ultra?
medium - high
I did that like 5 times. didn't help, maybe my GPU or CPU is dying?
everything stable and working correctly out of games? Ram and hard drive have no errors? Any strange bsod. What are temps (load and idle) gpu and cpu please.
No idea - I've been able to go only as far as 2.5GB and that's using VSR 1440p.
Sigh... No it's not. Just open your side panel and check for any dust. Could be overheating.
Most likely - though like I said - MSI 280X launch BioS had overheating VRMs and 2 of the memory modules don't have any cooling (plate doesn't cover them)
gpu idle 36 cpu idle 40-50
gpu load 76C cpu load 71C
You seem to always be in some sort of computer trouble xD
Sally: l Intel i5 4690k | | Corsair H55 | | Zalman z12 plus | | Hitachi 2TB HDD | | Samsung 840 Pro 128 GB | | ASRock Fatal1ty z97 Killer | | Corsair Vengeance 16 GB | | EVGA SuperNova 750 watt | | MSI 390 | | Windows 10|
that looks good. Pagefile maybe.. Hmm. What a pickle. Did you reinstall windows?
