Do i need better sound
Im going with Z97A Gaming 7
no the audio on msi motherboard is very good
https://linustechtips.com/topic/444844-do-i-need-better-sound/#findComment-5961637
What do you mean? You just mentioned a motherboard?
Intel Core i7 7770K | 32 GB's Ram 3000MHz | GTX 1080 Ti | 250GB SSD | 3TB 7400 RPM | Sound Blaster Z | ASUS ROG MG278Q | Razer Blackwidow Chroma | Final Mouse 2015 | Blue Yeti | Seinheiser HD 600's | Beyerdynamic DT 990 Pro | Aune T1 MK2
https://linustechtips.com/topic/444844-do-i-need-better-sound/#findComment-5961639
better in this case depends on being uber picky , if you're a regular dude you'll be more than happy with the on board setting with it's build in amp, otherwise start researching , do note that everybody's ears are different, so difference between a 200$ audio setup & a $2000 priced setup can have a very little effect on you personally
Details separate people.
https://linustechtips.com/topic/444844-do-i-need-better-sound/#findComment-5961689
