Cooling Tips
Solved by helping,
You should be fine. You might want to stick an intake in the bottom of the case and orient your two tops as exhaust and have your rear as intake or exhaust as per your choice.
A single 780 and an i5 should produce manageable heat in an R4. Keep in mind it is not a cooling optimized case.
Issac Zachary ·
Posted in Troubleshooting5 -
4
PopsicleHustler ·
Posted in Audio4 -
4
4
Greasy_Pudding ·
Posted in Servers, NAS, and Home Lab3 -
Sveeno ·
Posted in LTT Releases8 -
4
thrasher_565 ·
Posted in Hot Deals0
play_circle_filled
Latest From ShortCircuit:
