Hey guys, i'm building my very first pc and would like some advice on the build.
I got some help from friends and made a build which looks like --> http://ca.pcpartpicker.com/p/3HTxJx
In the future I'm planning to add another GPU and SLI it and might add another 32gb ram.
The PSU should be enough for what I want to do in the future, what i need help with is the cpu cooling. I'm not 100% sure if that's the best one for when i add another GPU n 16gb ram.
Any advice or opinion will be helpful, my budget will be around 2500$ CAD might go a little higher.
I'm in no hurry to build the PC and plan to wait for black friday or maybe even boxing day for much cheaper parts.
Thanks for all the help in advance
https://linustechtips.com/topic/444234-building-my-first-pc/
That PSU is good for two 980tis.
https://linustechtips.com/topic/444234-building-my-first-pc/#findComment-5953916
