Make accounts and you guys need to just log in when you need it.
 Just because you don't care, doesn't mean other others don't. Don't be a self-centered asshole. -Thank You a PSA from the people who do not say random shit on the internet.
https://linustechtips.com/topic/444169-freenas-help/#findComment-5953090
Heres the room set up.
POE jack which goes into a cisco ip phone, the phone has two ethernet ports on it one for power and calling the other for your computer.
I setup a router everything worked great I had wifi in my room no issues, a few hours later my router stopped working, my phone and laptop(macbook pro) could not connect to it wirelessly, but the wired connection did.
Bought a used router on kijiji had the same issue router works fine wired but wirelessly it just times out when you click to join it.
I have tried reseting it - nothing
I disabled the password - nothing
I reset and just plugged in the internet -nothing.
The only thing i can see that i messed up was , just for fun i plugged the router into the POE jack to see if i could get better speeds.
Any help would be greatly appreciated
https://linustechtips.com/topic/444169-freenas-help/#findComment-5970278
