I just installed a fresh windows 7 onto my computer and every time I installed my graphics drivers for my gtx 970 theres always some sort of problem. The first time I installed the drivers and rebooted the windows 7 logo animation finished then my screen went black and I could still hear the windows welcome sound. After that I installed windows 7 again and this time installed the driver from the CD it came with. This time it got past the logo but I can only see the desktop background no taskbar, logos or anything. Also when I try to ctrl alt delete it just gives me a black screen. It never did this before and I have no idea what to do about it. The only thing I'm about doing is installing windows 10 to a usb drive and install it.t
https://linustechtips.com/topic/444167-nivdia-graphics-problem/
How do I start in safemode? I heard you have to press F8 but thats a key to go into my bios. My motherboard is a asus z97-A
hold the shift key and press f8.
Did my post help you? Then make sure to rate it!
Check out my post on symbolic links! || PSU ranking and tiers || Pokemon Thread
https://linustechtips.com/topic/444167-nivdia-graphics-problem/#findComment-5953094
What are your specs, becuase I know when I cold boot, before I upgraded my RAM, I would have to sometimes wait a few minutes for the tabs and my shortcuts to load.
SPECS or it didn't happen. click the link in my signature.
CPU: Pentium G3258 @ 3.2GHz || GPU:(first release,used) MSI R9 270 OC || Motherboard:MSI Z97-G45 Gaming Motherboard || RAM: 8 GB G.Skill Sniper 1600 || Monitors: Vizio 22 in Ultra slim 1080p TV || Storage: Seagate barracuda 160 GB 7200RPM,(REFURB) 1TB toshiba 7200RPM || PSU: (stripped from 2013 CAD PC)Corsair CX600 build was under $420
BE SURE TO FOLLOW YOUR THREADS! READ THIS BEFORE POSTING IN TROUBLESHOOTING!! http://linustechtips.com/main/topic/40334-read-before-asking-for-help/
https://linustechtips.com/topic/444167-nivdia-graphics-problem/#findComment-5953931
Intel Core i7 4790k Not overclocked
16GB Corsair Vengeance
500gb WD Blue
GTX 970
Windows 7 Home Premium 64bit
ASUS Z97-A
https://linustechtips.com/topic/444167-nivdia-graphics-problem/#findComment-6013586
