Probably, its a Corsair
FX-6300 cooled by Nepton 240M | EVGA GTX 970 SuperClocked | 8GB G.Skill ValueRAM | Cooler Master 690 III | Sharkoon WMP 500 Bronze
Power supplies:
http://linustechtips.com/main/topic/406160-psu-ranking-and-tiers/ My F@h stats: http://fah-web.stanford.edu/cgi-bin/main.py?qtype=userpage&username=zyntaxable Intel vs. FX for gaming: http://linustechtips.com/main/topic/401217-more-updated-fx-vs-intel-for-gaming/
https://linustechtips.com/topic/444058-issue-psu/#findComment-5951444
I've had 2 different Titan's and a GTX 650. They all have artifacts if I leave them overnight. Would my PSU be the issue? Thank you.
Are you overclocking your GPU's or anything it shouldn't have an issue with artifacting.
https://linustechtips.com/topic/444058-issue-psu/#findComment-5951455
Yah that really shouldnt be the issue. I mean its POSSIBLE, try removing ONE GPU and run it overnight
Edit: just read some other comments. Do you have a multimeter?
https://linustechtips.com/topic/444058-issue-psu/#findComment-5951468
Nope. My GTX 780 did the same thing. All cards have been on this supply.
Did you ever try testing those cards on another system it seems a bit odd that would occur, also have you ever tried probing the PSU to see if it is giving the proper 12.00V and etc from it.
https://linustechtips.com/topic/444058-issue-psu/#findComment-5951482
No mulitmeter. This only happens if I leave my system in Windows, I wake up to see a screen of artifacting (I need to restart and I can't really leave anything that I want to save.)
https://linustechtips.com/topic/444058-issue-psu/#findComment-5951497
strange. Does the PSU make any audiable noise (other than the fan)? Can you hear anything with an AM radio tuned to static next to the GPU? Does the noise sound different when artifacting?
https://linustechtips.com/topic/444058-issue-psu/#findComment-5951520
That's kind of strange it occurs on wake from sleep seems almost like an issue with Windows to me, but are you running more than a single monitor setup I know on the AMD side it has this issue with artifacting which is fairly common even with waking from sleep.
https://linustechtips.com/topic/444058-issue-psu/#findComment-5951575
One monitor
https://linustechtips.com/topic/444058-issue-psu/#findComment-5951608
One monitor
Can you plug the GPUs into another system? Something tells me you have a funky motherboard. Try turning off the "Power Saving" features in the Power Options "Advanced" menu relating in any way to the PCI slots.
https://linustechtips.com/topic/444058-issue-psu/#findComment-5953068
No other system
Well there's your problem :)
Can you go to a friend's house and test it? You really need to test both the PSU and GPU.
https://linustechtips.com/topic/444058-issue-psu/#findComment-5953318
